    Tomb Raider 1 - black screen
    tomb raider
    5878
    • beerbaron
      beerbaron last edited by
      After I got to the point where i can choose to start (or load) the game, the screen goes black. No sound or video. It's a .bin file, I already tried to put the .cue with it and started from both. [RPi2, v3.2.11, HDMI, Bios in place.] Any hints or solutions? Thx..
      • digitaLumberjack
        I would say test it with an other rom. Maybe in iso format.
        • beerbaron
          Tried it with bin, iso and img format. Also ntsc, pal and german version. Always the same outcome.. =/
          • guzzo
            guzzo last edited by
            Hi, I tried with the french version and it does work. Tomb Raider (F) (SLES-00485) BIOS scph1001.bin When does the black screen happen ? At the very beginning  ?
            • beerbaron
              Awsome, I'll try it out. Yeah, it happens right at the very beginning. I start the game and it goes dark right away..
              • tiwacs
                tiwacs last edited by
                sorry for my very bad english The same as GuZzO, it works fine for me. It looks like a common problem with tracks definition. Psx emulator have to jump to another track when you choose load or start a new game. If the .cue is not exactly as expected you got a black screen. But i don't understand why it doesn't work with the .iso ... Bad convert ? Try a look at
                • beerbaron
                  Thanks GuZzO, Tomb Raider (F) (SLES-00485) works fine. 😃
                  101.4k
