    Request: Tutorial for connecting a tablet pc with recalbox
    request tutorial connecting tablet recalbox
    2736
    • MilesCW
      MilesCW last edited by
      It's pretty hard to be honest and I would actually need a step by step guide.
      After I connected at the SSH nothing really works anymore for me or I simply have no idea what to do next.
      gnubit Substring 2 Replies Last reply Reply Quote 0
      • gnubit
        gnubit @MilesCW last edited by
        @MilesCW
        You may want to be a little more specific so someone here can help. What issues are you experiencing and what are you having trouble with?
        MilesCW 1 Reply Last reply Reply Quote 0
          Substring @MilesCW last edited by
          @milescw this all depends on what you want to do once connected. Forget the sudo and apt commands, we are not based on raspbian
          • MilesCW
            MilesCW @gnubit last edited by
            @gnubit @Substring
            I want to use it as a screen when I'm out of the house.
            I'm sure it's likely easier to connect with a laptop/notebook but I really would appreciate it if I could play anywhere, especially when I'll start traveling.
              @milescw ok, but this still doesn't point me to commands you wish to run
              • MilesCW
                MilesCW @Substring last edited by
                @substring What is there else to say? I simply want to use a tablet pc as a screen for Recalbox. Is it possible or likely not? And if yes, how?
                  @milescw as a screen ? The tablet pc itself should be recalbox, which can be booted on USB
