    Solved PSX Games goes back to menu
    Emulator Arcade/PC/Console
    goes
    2989
    • ash1390
      ash1390 last edited by
      hi. i setup old netbook for retro gaming.
      everything is fine except PSX.
      when i select PSX with default Emulator (Mednafen) it just goes black for a few secs then goes back to menu and won't run psx run.
      unless i change the Emulator to PCSX it works and run any games but at 40-45 fps...and i read Mednafen is faster (not accurate) dew to my hardware limit.
      so plz help me fix it or any setting that i can get full FPS on old and s**tty netbook for PSX.
      thanks.
      • barbudreadmon
        barbudreadmon last edited by
        @ash1390 said in PSX Games goes back to menu:
        Definitely not, i don't know where you read that, but actually if pcsx run at 40-45 fps on your old laptop, beetle-psx (mednafen) will probably run at 30-35 fps. While pcsx will run full speed on a x86 with a cpu around ~2Ghz, and you can improve performance significantly by using a value of 1 (up to 5) for frameskip in core options; beetle-psx won't run full speed on anything below ~2.2Ghz, and there is no core option to improve significantly performance. That's my personal experience from running both of them on a dedicated x86 with a cpu throttling between 2 and 2.5 Ghz.
        There is a plan to include a cross-arch dynarec to beetle-psx though (i think there is a 750$ bounty on this task in libretro patreon), so i guess the emulator will run really well when it's done.
        Libretro developper :
        • FBAlpha FBNeo (Arcade)
        • Kronos (Sega Saturn/ST-V)
        • YabaSanshiro (Sega Saturn)
        ash1390 1 Reply Last reply Reply Quote 0
        • ash1390
          ash1390 @barbudreadmon last edited by
          @barbudreadmon
          thank you so much for info...
          can you give me more detail and how to get better FPS on PCSX then?
          i'm new to Recalbox.
          thanks a lot.
          • barbudreadmon
            barbudreadmon @ash1390 last edited by
            @ash1390 What's the cpu on your laptop and what's the game you are trying to play ?
            • ash1390
              @barbudreadmon
              it's atom n455. game like harvest moon... or RE1-3.
              • barbudreadmon
                barbudreadmon @ash1390 last edited by barbudreadmon
                atom n455
                Go to core options and set a value of 2 for frameskip, if it's not enough try higher values, but honestly i don't think there is a way to get psx running smoothly on a x86 @ 1.66Ghz. Due to the lack of x86 dynarec, that's a very bad choice of hardware for this system.
