    Amiga & NES Emu doesn't work!?
    Emulator Arcade/PC/Console
    amiga nes doesnt work
    6839
    • jochen
      jochen last edited by
      Hi,
      generally the Racalbox is really nice. It's for me a bit more home then Retropi.
      But, Amiga Emulator don't run and also the NES dont run.
      On Amiga Emu I've placed the correct MD5 Kickstarts in the suggested folder and also ADF images upload. But the emulator dont start.
      The same Thing with NES. I've upload zipped and not zipped .nes files, but nothing.
      In both cases I stert the whished image from GUI, the screen is dark and after a while the GUI comes back without any warning or what ever. 😞
      What is wrong there?
      OyyoDams Substring 2 Replies Last reply Reply Quote 0
        OyyoDams Staff @jochen last edited by
        @jochen Hi,
        First of all what is your board ?
          Substring @jochen last edited by
          @jochen NES does work, something must be wrong in your setup. Ca n you make a support archive please ?
          • jochen
            Hi, I've test it on Pi 2 and Pi 3 (without +).
            How can the setup be wrong? Have nothing done on NES. Only copy the roms...
            What does mean "support archive"?
              @jochen go to the web interface with your computer (http://recalbox/ or http://recalbox.local), support section, execute the script, and paste the support link here
              • jochen
                Ok, Amiga now also is running. Have coied the rom one folder too deep. A error message would be helpful.
                Only the NES isn't start the roms.
                Here the support Link: https://file.ac/Jc9eIjCT8OM/
                  @jochen can you make the same archive, but just after launching a nes rom, not amiga please ?
                  • jochen
                    Ah, it's senstitve to last doing... nice!
                    Here it is: https://file.ac/Sbj8T4AzD6Q/
                      OyyoDams Staff @jochen last edited by OyyoDams
                      @jochen thanks. I don't see anything wrong in the logs. I've just tried the same rom on nes (rpi3), and it works. Do you have the same issue with othter nes roms ?
                      Can you try other libretro / retroarch emulators (snes, megadrive or gameboy for example) and tell me if it works ?
                        @jochen can you also edit recalbox.conf and add nes.args=-v then start again 10 yard fight, then again a support archive, please ?
                        • jochen
                          Ok, will try it at evening...
                          All other emulators are running correct.
                          Only the NES don't do anything. No one of my roms are started successful.
                          • jochen
                            Ok, was done it.
                            Here the new file: https://file.ac/I_S4g2kjAhg/
                              @jochen please try the following:
                              1. Connect to the shared folder through network
                              2. Go to system/configs/retroarch/
                              3. Rename retroarchcustom.cfg to retroarchcustom.cfg.old
                              4. Try again to launch a nes rom
                              • jochen
                                Has no effect. 😞
                                • jochen
                                  Nobody an idea?
                                  both versions... for Raspi2 and Raspi3 instantly don't work with nes roms after fist installation.
                                  Is this generally a bug in the actual version?
                                    @jochen said in Amiga & NES Emu doesn't work!?:
                                    Nope you're the only one with this issue... Maybe a bad romset ?
                                    • jochen
                                      jochen last edited by acris
                                      Could be...
                                      Would need a rom what is running anywhere to test it here.
                                      Was loading mine from xxxxxxorg ...
                                      EDIT MODO
                                      no link with copyright contents
                                      please read rules thanks.
                                        please try others roms sources
                                        • jochen
                                          Ok, will try it...
                                            @jochen i use blade buster for all my tests on all boards i own, so trust me, it does work ! I'll have a look at your support archive tonight
