    Solved Partition Usb Key
    partition usb key
    • leprive
      leprive last edited by
      Hello,
      Sorry if this has been asked before, could not find it.
      I'm using recalbox on my pc with a bootable usb key. This is fantastic.
      It is using my PC'w wifi to access the network.
      I find it a pain to transfer my roms through Wifi, I was wondering if the following was possible : partition the usb key, save 8Go to install the system and having the rest as a data partition with just the roms.
      -If it is posible would it affect negatively the performances?
      -I'm using osx do you know how to partition a usb key easily?
      -What format should I use for the data partition?
      Thx a lot for your answers
        paradadf Staff @leprive last edited by paradadf
        @leprive afaik, not possible. I‘d suggest copying everything (roms and bios stuff I mean) to an usb stick and plug it in another port and use the file manager in kodi to transfer them to recalbox.
        leprive 1 Reply Last reply Reply Quote 0
        • leprive
          Ok Thanks for this answer. This is a good trick never thought of that.
          I might even not need the second usb key as kodi has access to the harddrive on the pc, that also coutains the rom.
          • leprive
            leprive @paradadf last edited by
            @paradadf I want to add a [solved] to the subject but dot know how to do it
              @leprive just read my signature 😉 but I already did it for you.
