    Moonlight - Sound through Jack output.
    Emulator Arcade/PC/Console
    moonlight sound through output
    3420
    • Bilbotorm
      Bilbotorm last edited by
      Hello everyone,
      Just trying to get a bit of help. Despite some search on the web, I can't find any answer on my problem.
      I setup moonlight on my recalbox (with Rasp pi 3) and it works flawlessly when it comes to control & graphics.
      But I have absolutely no sound.
      Right now, my sound is taken from the jack output of the pi (and set up in recalbox UI as "jack", auto does not work and seems to go through HDMI I guess?)
      It works perfectly in all "native" games, but when using moonlight it just never work.
      I am not quite familiar with moonlight, any guidance on where I should look to fix this ?
      I guess this "force jack" option must be setup in Moonlight conf file, but not sure where to look at...
      Thanks in advance
      Cheers
      Bil
        Substring @Bilbotorm last edited by
        @bilbotorm hi
        Have a look zt the moonlight conf file in sytem/configs/moonlight
        • Bilbotorm
          Bilbotorm last edited by Bilbotorm
          Hello
          Thank you for your reply, looking at the moonlight config I can read the following:
          ##Play audio on host instead of streaming to client
          #localaudio = false
          ##Select audio device to play sound on
          #audio = sysdefault
          shall I put jack ? what's the syntax ?
          thanks !
          • Dragu
            @Bilbotorm
            It seems, you are not the first having the problem. Look once here with solution :
            https://github.com/irtimmer/moonlight-embedded/issues/383
            Bilbotorm 1 Reply Last reply Reply Quote 0
            • Bilbotorm
              Bilbotorm @Dragu last edited by
              @dragu
              Hello Dragu,
              Thanks for taking the time to reply
              I looked at your link, and tries to do the following:
              #localaudio = true
              #audio = local
              with no success, still no sound (neither from origin pc or from the recalbox pi3)
              if anyone knows...?
              • Dragu
                @Bilbotorm
                You must take away the # before parameter.
                -audio local
                Bilbotorm 1 Reply Last reply Reply Quote 1
                • Bilbotorm
                  @dragu
                  Thank you so much, all's fixed !!!!
                  Sound is now output properly.
                  101.4k
