    Roms does not work anymore
    Emulator Arcade/PC/Console
    rooms does anymore
    3300
    • bernardoortega
      bernardoortega last edited by bernardoortega
      I have used parted to expand my sd card to 64 Gb. I may think this could be the cause but not sure. Everything looks fine except that now no noms work, and they back to emulator when you try to run them. Everything else works as normal.
      any clue?
        Substring @bernardoortega last edited by
        @bernardoortega please make a support archive
        bernardoortega 1 Reply Last reply Reply Quote 0
        • bernardoortega
          @Substring here is the url for the support archive
          many thanks
          https://file.ac/9y-UdWwWC_A/
          • bernardoortega
            bernardoortega @Substring last edited by
            @substring in case is with no capitals:
            thanks
              @bernardoortega looks like you've made some other changes god knows where, because it's trying to run a libtreto emulator instead of libretro
                like mame.emulator=libreto
                • bernardoortega
                  @substring yes, that was my last change to see if doing it it will work, but of course it did not. I will revert back to the correct word, but that is not the issue.
                  does normally works when you use Gparted to extend partitions_
                  thanks
                    @bernardoortega start a game that crashes then make a support archive
                    bernardoortega 2 Replies Last reply Reply Quote 0
                    • bernardoortega
                      @substring i just modified to libretro and rebooted. I tried to run a couple of games, one from mame and another from NEO and neither of them worked. Here is the new support file:
                      https://file.ac/QRX2bCwz95o/
                      thanks in advance
                      • bernardoortega
                        bernardoortega @Substring last edited by bernardoortega
                        @substring hello again, i made them working again. I have changed the advanced emulator options in Libretro i just selected as emu libretro and FBA and auto and in mame i selected advancedmame as emulator. Is that correct? now they all work
                        thanks
                          voljega Banned @bernardoortega last edited by
                          @bernardoortega well obviously you didn't even try to read arcade documentation and you know nothing about it. Start by reading the wiki
