    Download and use alternative cores through Retroarch menu
    download alternative cores through retroarch
    5973
    • horotony
      horotony last edited by
      I was wondering, since you can actually download new cores through Home + B menu, but they don't seem to work (I wasn't really expecting either).
      I ask that because I really wanted to run some MSU-1 enhanced games and other hacks that expands SNES roms over 4mb size limit, but none of the cores current present on Recalbox seems to run those games.
      Is there a solution or something in the works right now? I'd love to have lr-snes9x core on recalbox 😃
        HELLO
        no need to download core.
        you need to use a good core, select your game , select button, edit metadata game
        choose emulator : libretro
        choose core : snes-9x
        horotony 1 Reply Last reply Reply Quote 1
        • horotony
          horotony @acris last edited by
          @acris Snes9x isn't working for MSU1 enhanced roms (it can't load the proper file, i'm not sure this version is compatible) and also cant run roms over 4mb either.
            https://docs.libretro.com/library/snes9x/
            I tried few games msu-1
            It work very well with default core or change snes9x core.
            You have a problem with your rom.
            horotony 1 Reply Last reply Reply Quote 0
            • horotony
              horotony @acris last edited by horotony
              @acris is that so? Can you tell me how to proper load MSU-1 roms? I'm probably doing something wrong then.
              Edit: I finally made it work. I just needed to make SNES9x (and NOT SNES9X-NEXT) the default core/emulator.
              But.. what about roms over 4mb ("hi-roms"), is there any documentation regarding that? I know its something very specific and not very used, but there's a translation patch for a game I love that uses more than 4mb and I couldn't make it work on snes9x.
                acris @horotony last edited by acris
                @horotony said in Download and use alternative cores through Retroarch menu:
                What game ? exactly ?
                • horotony
                  @acris
                  There's a portuguese translation of Donkey Kong Country 2, which expands the rom size to 6mb.
                  It's on this video https://youtu.be/Z_qZKAxTpBU?t=113.
                    @horotony
                    I don't understand your problem, hack rom, translated rom , patch rom work all very well with default core.
                    I patched Donkey Kong Country 2 usa rom with translated patch ips and it s work fine.
