    Bluetooth menu doesn't work Rpi zero W
    GamePad/GPIO/USB encoder
    bluetooth doesnt zero
    1716
    • dm34942331
      dm34942331 last edited by
      I'm trying to use the menu for pair bluetooth devices on recalbox 4.1 working on a Raspberry Pi Zero W, but when i select "pair a bluetooth device" appear the black image of recalbox with the version and freeze there. Then i try witn ssh and bluetoothctl and it works perfectly. I want to use the menu. What can i do?
        Substring @dm34942331 last edited by
        @dm34942331 hi
        Looks like ES crashed. You could eventually circumvent that by going the manual way (see the wiki). But still, i wonder why it crashed
        dm34942331 1 Reply Last reply Reply Quote 0
        • dm34942331
          dm34942331 @Substring last edited by
          @substring when I try to re-open ES again from ssh while it's freezed I obtain "Error creating SDL window"
            @dm34942331 mmhhhh .... Which recalbox version are you running ?
            • dm34942331
              @substring Recalbox 4.1 tomorrow I will install 4.0
                OyyoDams Staff @dm34942331 last edited by
                @dm34942331 what ? Please install the latest version! Current is 18.04.20
                101.4k
