    Benchmarking script
    Community projects
    benchmarking script
    8225
    • Gaetan
      Gaetan Theme moderator @Substring last edited by Gaetan
      @substring I don't know what is a md5, but I'll be happy to give it 🙂
      Better like this 🙂 ? :
      text alternatif
      @voljega if I can help ?
      Substring voljega 2 Replies Last reply Reply Quote 0
        Substring @Gaetan last edited by
        @gaetan oh yeah
        Md5 is a the hash of a file. It's unique for any file
        Regarding KI, could you get it to launch on mame2010 ?
        • Gaetan
          @substring No, KI 1&2 doesn't launch with mame2010
          Here is my gamelist :
          text alternatif
          I don't know how get rid of the "killer instinct (v1.50) and killer instinct 2 (v1.4) in the gamelist
          • Dragu
            Dragu Banned last edited by
            @Substring
            Hi, it was here : https://forum.recalbox.com/topic/13588/strange-error-in-dosbox/58
              voljega Banned @Gaetan last edited by
              @gaetan said in Benchmarking script:
              This is done by editing your gamelist.xml or configuring your scraper....
              Can you also give me the exact rom names for KI & KI2 ?
              • Gaetan
                Gaetan Theme moderator @voljega last edited by Gaetan
                @voljega Here are the names of the roms :
                • kinst.zip
                • kinst2.zip
                Oh yes ? it's something that I can find in the forum ? I couldn't find it.
                  Substring @Dragu last edited by
                  @dragu now i remember. So a few facts :
                  • it's dos only
                  • i'm not even sure it has some text output i could read.
                  As for now, i prefer focusing on retroarch only because i can test most of systems with the same code
                    So, here is a first shot :
                    #!/bin/bash
                    # read parameters
                    # $1 is the core
                    RA_CORE="-L /usr/lib/libretro/$1_libretro.so"
                    # $2 is the rom
                    RA_ROM="$2"
                    # Consider the game should run at 60Hz
                    FPS=60
                    # Start the emu
                    NB_FRAMES=600
                    RA_OPTS="--verbose --max-frames=${NB_FRAMES}"
                    RA_CONFIG="--config /recalbox/share/system/configs/retroarch/retroarchcustom.cfg"
                    RA_OUTPUT_LOG=/tmp/ra.log
                    rm $RA_OUTPUT_LOG
                    /usr/bin/time -v /usr/bin/retroarch $RA_OPTS $RA_CORE $RA_CONFIG "$RA_ROM" > $RA_OUTPUT_LOG 2>&1
                    # Get the emulator output
                    FRAMES_EXPECTED=`grep "[INFO] Threaded video stats" "$RA_OUTPUT_LOG" | sed "s+.*Frames pushed: \([0-9]*\).*+\1+"`
                    FRAMES_DROPPED=`grep "[INFO] Threaded video stats" "$RA_OUTPUT_LOG" | sed "s+.*Frames dropped: \([0-9]*\).*+\1+"`
                    FRAMES_RENDERED=$(($FRAMES_EXPECTED - $FRAMES_DROPPED))
                    TIME_RUN=`grep "Elapsed (wall clock) time (h:mm:ss or m:ss):" "$RA_OUTPUT_LOG" | sed "s/.*: \([0-9]*\)m \([0-9]*\)\.\([0-9]*\)s/\1 \2\ \3/"`
                    NB_MINS=`echo $TIME_RUN | cut -d ' ' -f 1`
                    NB_SECS=`echo $TIME_RUN | cut -d ' ' -f 2`
                    NB_CENS=`echo $TIME_RUN | cut -d ' ' -f 3`
                    CPU_LOAD=`grep "Percent of CPU this job got:" "$RA_OUTPUT_LOG" | sed "s/.*: \([0-9]*\)%.*/\1/"`
                    # Do what we need
                    # The game should have run for NB_FRAMES / FPS seconds, how long did it really take ?
                    EXPECTED_TIME=$(($NB_FRAMES / $FPS))
                    REAL_TIME=$(($NB_MINS * 60 + $NB_SECS))
                    OVERHEAD=$(($REAL_TIME - $EXPECTED_TIME))
                    # Looks like RA start emulation at [INFO] Initializing rewind buffer with size: 10 MB
                    # or [INFO] Loading history file: [/recalbox/share/system/configs/retroarch/content_image_history.lpl].
                    # And it ends at [INFO] Saved core options file to "/recalbox/share/system/configs/retroarch/cores/retroarch-core-options.cfg"
                    echo "$FRAMES_EXPECTED - $FRAMES_DROPPED = $FRAMES_RENDERED ($EXPECTED_TIME + $OVERHEAD / $CPU_LOAD)"
                    echo -n "1st score (100 max):"
                    python -c "print round(100*$FRAMES_RENDERED/$NB_FRAMES*$NB_FRAMES/$FPS/${REAL_TIME}.${NB_CENS}, 2)"
                    The final result is a mark out of 100. Shouldn't be above 100. 100 would mean instant load of retroarch + start of the game, which is nearly impossible.
                    The basic idea : retroarch is run for 600 frames (assume the game is 60Hz). Then compute a few details :
                    • frames rendered
                    • frames dropped
                    • total time elapsed
                    • CPU %
                    Made a few tests with killing blade (the PGM logo is already stuttering on a non overclocked pi3)
                    Pi3 output example:
                    # bash recalbox-bench.sh fba ../roms/fba_libretro/killbldp.zip
                    600 - 0 = 600 (10 + 4 / 88)
                    1st score (100 max):67.98
                    C2 output example:
                    # bash recalbox-bench.sh fba ../roms/fba_libretro/killbld.zip
                    600 - 0 = 600 (10 + 2 / 69)
                    1st score (100 max):81.23
                    Small explanation on the first result line
                    600 : number of frames expected
                    0 : number of frames dropped
                    10 : expected run time (600 frames at 60 Hz)
                    2 : run time overhead (means the full length of retroarch took 12s, despite i'm not showing the rest of the value but do have it in the script)
                    69 : CPU percentage
                    So from here you can notice:
                    • the pi3 took something like 14 to 15s for the overall launch of RA + ROM execution + quit RA whereas it took 12 to 13s on the C2
                    • the PGM logo was consuming 88% on pi3 vs 69% on the C2. And I tell you : the sound doesn't stutter on the C2
                    Overall, this bench doesn't look that bad for now 🙂
                      @gaetan
                      bon pour le Golden Axe j'ai réussi, le jeu mets des plombes à se lancer
                      pour Killer Instinct j'ai aussi rĂ©ussi sur mame2003, par contre ça ne fonctionne pas sur mame2010 mĂȘme avec le CHD dans la bonne version
                      Un peu bizarre les CHD d'ailleurs celui de Killer Instinct fait genre dans les 90mo mais j'ai constatĂ© qu'il y en a un pour le premier Gauntlet (???) qui fait 1Go (????) taille mĂ©moire qui ne devait mĂȘme pas ĂȘtre atteignable Ă  l'Ă©poque.... (1985) c'est quoi le dĂ©lire ?
                      • carlajiji
                        carlajiji last edited by
                        That's a good idea!
                        • Gaetan
                          Gaetan Theme moderator last edited by
                          Hi @Substring !
                          I would like to try the benchmark script.
                          I really feel like the beta of pi3b+( 1.4ghz) is slower than my pi3b oc at 1.3ghz.
                          With this test I could be sure if this is just a feeling or something isn't right.
                          You said it's only for retroarch games but of course, the games I would like to try are not, they are DC and PSP. Could you managed to make the script for those emulators ?
                          If not, I can try some PSX games, but with PSX i don't feel that the framerate is skipping.
                          Tell me, how to use the script ?
                          100.2k
