    Solved Syncing saves
    syncing saves
    5217
    • MinZe
      MinZe last edited by
      Hi, I have retroarch on my android device too and I want to sync my savegames, I could use onedrive, google drive, dropbox, an own ftp online server, almost anything would be useful. What I need is to send the changed savegame and to download it too when started the recalbox or the game(it could be both).
        Substring @MinZe last edited by
        @minze how skilled are you regarding linux ?
        • MinZe
          @Substring I'm studying informatics engineering at university, I'm almost sure I won't have problem ^^
            @minze then the best would probably to add a custom init script that would sync at stop
            • MinZe
              Right now I'm trying to install syncthing but I can't install the package... is there any way? apt-get and things like that doesn't work
              • idarius
                idarius last edited by
                hi, i think you can use rsync in a script.
                To install new command you need to compil recalbox youself, there is no apt-get.
                rsync is already in recalbox.
                MinZe 1 Reply Last reply Reply Quote 0
                • MinZe
                  MinZe @idarius last edited by
                  @idarius Thanks, Im giving a look at it.
                  • MinZe
                    I have been able to sync saves to google drive thanks to rclone, which uses rsync. now what I need is to know how to activate an script everytime a game is closed
                      voljega Banned @MinZe last edited by
                      @minze you should add a command launch in python script emulatorlauncher.py
                      • MinZe
                        MinZe @voljega last edited by
                        @voljega Yeah, I figured out at midnight, the thing is that right now I think that I wasn't able to execute-it.
                        this is my code for the .sh:
                        #!/bin/bash
                        rclone sync gdmedia:rpi /recalbox/share/saves/
                        echo finished
                        and this is for my emulatorlauncher.py
                        def main(args):
                            subprocess.call('./syncFiles.sh')
                            playersControllers = dict()
                            if not args.demo:
                        what am I doing wrong?
                        PS: As soon as I fix that I'll make a tutorial, because there is no one yet on how to sync files with drive/dropbox/etc
                        voljega 2 Replies Last reply Reply Quote 0
                          @minze well first your script should be launched after the emulator was launched, you some to launch it before
                          also I personnaly use os.popen to launch command :
                          os.popen('cp -R '+whdFilespath+'/* '+mountPointWHDL)
                          you can also look into utils/runner.py and Command.py for something a little more complicated, but perfectly tweakable.
                          and keep your modifications backed up because all of that can be erased at each update
                          • MinZe
                            MinZe @voljega last edited by MinZe
                            @voljega Well that was an script to see if it worked because it produces changes easy to see.
                            And the script should be launched everytime a game is ran right? at least that's what I thought.
                            Should I modify the script like that?
                            edit:(I've modified the .sh to have an start argument)
                            if __name__ == '__main__':
                                signal.signal(signal.SIGINT, signal_handler)
                                pa**er = argpa**e.ArgumentPa**er(description='emulator-launcher script')
                                pa**er.add_argument("-p1index", help="player1 controller index", type=int, required=False)
                                pa**er.add_argument("-p1guid", help="player1 controller SDL2 guid", type=str, required=False)
                                pa**er.add_argument("-p1name", help="player1 controller name", type=str, required=False)
                                pa**er.add_argument("-p1devicepath", help="player1 controller device", type=str, required=False)
                                pa**er.add_argument("-p1nbaxes", help="player1 controller number of axes", type=str, required=False)
                                pa**er.add_argument("-p2index", help="player2 controller index", type=int, required=False)
                                pa**er.add_argument("-p2guid", help="player2 controller SDL2 guid", type=str, required=False)
                                pa**er.add_argument("-p2name", help="player2 controller name", type=str, required=False)
                                pa**er.add_argument("-p2devicepath", help="player2 controller device", type=str, required=False)
                                pa**er.add_argument("-p2nbaxes", help="player2 controller number of axes", type=str, required=False)
                                pa**er.add_argument("-p3index", help="player3 controller index", type=int, required=False)
                                pa**er.add_argument("-p3guid", help="player3 controller SDL2 guid", type=str, required=False)
                                pa**er.add_argument("-p3name", help="player3 controller name", type=str, required=False)
                                pa**er.add_argument("-p3devicepath", help="player3 controller device", type=str, required=False)
                                pa**er.add_argument("-p3nbaxes", help="player3 controller number of axes", type=str, required=False)
                                pa**er.add_argument("-p4index", help="player4 controller index", type=int, required=False)
                                pa**er.add_argument("-p4guid", help="player4 controller SDL2 guid", type=str, required=False)
                                pa**er.add_argument("-p4name", help="player4 controller name", type=str, required=False)
                                pa**er.add_argument("-p4devicepath", help="player4 controller device", type=str, required=False)
                                pa**er.add_argument("-p4nbaxes", help="player4 controller number of axes", type=str, required=False)
                                pa**er.add_argument("-p5index", help="player5 controller index", type=int, required=False)
                                pa**er.add_argument("-p5guid", help="player5 controller SDL2 guid", type=str, required=False)
                                pa**er.add_argument("-p5name", help="player5 controller name", type=str, required=False)
                                pa**er.add_argument("-p5devicepath", help="player5 controller device", type=str, required=False)
                                pa**er.add_argument("-p5nbaxes", help="player5 controller number of axes", type=str, required=False)
                                pa**er.add_argument("-system", help="select the system to launch", type=str, required=True)
                                pa**er.add_argument("-rom", help="rom absolute path", type=str, required=True)
                                pa**er.add_argument("-emulator", help="force emulator", type=str, required=False)
                                pa**er.add_argument("-core", help="force emulator core", type=str, required=False)
                                pa**er.add_argument("-ratio", help="force game ratio", type=str, required=False)
                                pa**er.add_argument("-demo", help="mode demo", type=bool, required=False)
                                pa**er.add_argument("-netplay", help="host/client", type=str, required=False)
                                args = pa**er.pa**e_args()
                                command = './syncFiles.sh start'
                                os.popen(command)
                                exitcode = main(args)
                                time.sleep(1)
                                exit(exitcode)
                              @minze there no way you're in the right folder when launching the script so either try to use the absolute path or move to it before launching it
                              • MinZe
                                @voljega Ooh, I thought that as I that script was in the same folder that the py, I could use that, yeah it makes sense that it doesn't make sense. Thanks ❤ i'll try it as soon as I arrive home.
                                  Cool hope it works
                                  @minze said in Syncing saves:
                                  You can also work on official integration, because this is a feature that users regularly ask for 😉
                                  • MinZe
                                    @voljega Yeah, I'll take a look at it too
                                      @minze your script is anyway launched before the emulator, i thought you wanted it right after ?
                                      • MinZe
                                        MinZe @Substring last edited by
                                        @substring Yeah I want to execute the script:
                                        1. On start, once wifi is enabled.
                                        2. When any game is launched.
                                        3. if possible, when any game is closed
