    4:3 in DosBox on Raspberry Pi
    Emulator Arcade/PC/Console
    dosbox
    4855
    • Clint Hobson
      Clint Hobson last edited by
      Hi guys, I am using Batocera but no one on the forums seems to know the answer to this. I notice Recalbox uses a similar version of Dosbox so I thought I'd give it a try here.
      DosBox always runs at full width on my 800x480 HDMI 5" display, so everything looks stretched and wrong in wide screen and it should be cropped to 640x480. But how do I do this?
      I found the dosbox.conf file to make changes with, but setting aspect=true doesn't fix the problem like it does on the desktop version.
      • ian57
        Are you sure? Or is it Batocera that uses a simular release of dosbox?
        Please use Recalbox and you will have some support here.
        Clint Hobson 1 Reply Last reply Reply Quote 0
          voljega Banned @Clint Hobson last edited by voljega
          @clint-hobson said in 4:3 in DosBox on Raspberry Pi:
          All I can say is that on Recalbox it should be enough and it works
          Maybe you can try it on a spare SD card.
          • Clint Hobson
            Clint Hobson @ian57 last edited by
            I'm using Recalbox now, looks like the settings format is identical to Batocera and it was easy to find my way around - and I still can't get dosbox to obey any aspect ratio settings, not in the UI, and not in either of the two config files - dosbox.conf or dosbox-SVN.conf
              @clint-hobson you shouldn't modify those file but create a dosbox.cfg in your game directory, see there : https://github.com/recalbox/recalbox-os/wiki/How-to-use-DOSBox-to-emulate-DOS-games
              still it's strange that it isn't working, works fine for me (but I'm on 16/9 screen)
              you can try maybe with the custom dosbox.cfg linked in the wiki page
              • Clint Hobson
                Clint Hobson @voljega last edited by Clint Hobson
                @voljega But do you have black bars on the side of your screen so that the game is 4:3, or is it stretched to fill the full width of your screen?
                This is what I'm seeing
                alt text
                This is what I want to see
                alt text
                  @clint-hobson yes I have the second one in real 4/3
                  • Clint Hobson
                    @voljega Ah ok, are you using a computer monitor, or TV, or one of those small HDMI displays for the Raspberry Pi (like mine? Mine's a 5" 800x480)
                    Can I see your dosbox.conf?
                      @clint-hobson computer screen.
                      as I said you can see the dosbox.cfg from the wiki page I linked 😉 there's a pastebin link
                      • Clint Hobson
                        @voljega And just to double check - are you running this on a Raspberry Pi? (or your desktop PC?)
                          @clint-hobson pi3
                          • Clint Hobson
                            @voljega Wow ok. I just tried it the way you have it - connecting my Pi3 to my 16:10 computer monitor via HDMI, and simply changing "aspect=true" from the default conf above, does indeed work. It just doesn't work on my little 5" LCD... so weird...
                            • Dragu
                              @Clint-Hobson
                              If the Hdmi goes over a TFP401 board to the screen, the TFP401 driver does not have a video scaler. Just as info.
                              • Clint Hobson
                                Clint Hobson @Dragu last edited by
                                @dragu What's confusing me is - I thought the aspect correction was done by Dosbox - it draws an image to the display that is the full resolution of the display, and the image consists of the game content with black bars on either side - all drawn by Dosbox.
                                So it boggles my mind that the black bars disappear when I simply switch from my widescreen monitor to my 5" widescreen display. What is going on here?
                                • ian57
                                  @Clint-Hobson everything is here for the configuration of you screen https://github.com/recalbox/recalbox-os/wiki/TFT5-Screen-HDMI-(EN)
                                  "Remember, the TFP401 driver does not have a video scaler! If you don't feed it exactly 800×480 pixels the image will not stretch/shrink to fit! So we need to configure the resolution in the config.txt"
                                  • Clint Hobson
                                    Clint Hobson last edited by Clint Hobson
                                    @ian57 Wow - that was the problem after all this. Thank you 🙂
                                    In my defence, it didn't appear that I needed these settings as the Recalbox front end looks perfectly fine - pixel perfect, no glitchy pixels due to wrong resolution, the full screen is used - and indeed, the other emulators have their own black bars on the side and are already aspect correct. It was only Dosbox with the problem. In fact I only went and applied these settings just to say I had, I didn't expect it to make a difference...
                                    ian57 1 Reply Last reply Reply Quote 1
                                    • ian57
                                      ian57 Staff @Clint Hobson last edited by
                                      @clint-hobson As always... RTFM 😄
                                      • Clint Hobson
                                        Clint Hobson @ian57 last edited by Clint Hobson
                                        @ian57 True... but my understanding (from the "manual") was that these settings were for if your display isn't recognised or displaying incorrectly... so as it was displaying correctly for everything - the Recalbox interface, every emulator - except for one emulator, and only one aspect of that emulator, it seemed like the problem with the one emulator was what needed fixing.
                                        It was an insidious problem... and I'm glad to have had the help from you guys to fix it.
