    Dreamcast issue
    Emulator Arcade/PC/Console
    dreamcast issue
    6
    16
    8719
    • raiyoku
      raiyoku last edited by
      Hello,
      I would need your help, I bought a raspberry pi3 b months ago and downloaded gdi and cdi for Dreamcast. However, none of them worked.
      I searched for solutions on forums but nothing worked. I checked my isos, I tried different versions of the games, I created folders to place gdi files etc.. but nothing works.
      In most of the case, the game just doesn't open and sometimes it opens but I just have a blackscreen with noises.
      I was on Recal box 44.1 and I updated to the last version to see if it would work with it but no 😕
      I would appreciate if you could help me.
      I thank you in advance. 🙂
      • SylGaud
        SylGaud last edited by
        @raiyoku are your BIOS ok?
        https://github.com/recalbox/recalbox-os/wiki/Add-system-bios-(EN)
        raiyoku 1 Reply Last reply Reply Quote 0
        • raiyoku
          raiyoku @SylGaud last edited by
          @sylgaud my 2 dc bios are okay, I even tried the region free ones
          • raiyoku
            My dc_bios is ok but I found that my dc_flash is not ok and i can't find the good one anywhere across the web. it's the only bios i lack to have all of them on my recalbox. Do you know if i really can find it ?
              voljega Banned @raiyoku last edited by
              @raiyoku yes you can
                Substring @raiyoku last edited by
                @raiyoku o/
                Lance une rom, et quand c'edt revenu sous es, fais une archive de support stp
                • raiyoku
                  raiyoku @Substring last edited by
                  @substring https://file.ac/iVSUs6BCcgM/ voili voilou 🙂
                  OyyoDams abunille 2 Replies Last reply Reply Quote 0
                    OyyoDams Staff @raiyoku last edited by
                    @raiyoku Tes bios sont OK mais il y a un souci dans la rom que tu lances:
                    file[1] "CrazyTaxi(Europe)(Track1).bin": FAD:0, CTRL:4, SSIZE:2352, OFFSET:0
                    Verify Failed  : file!=0
                    • abunille
                      abunille @raiyoku last edited by abunille
                      @raiyoku
                      That seems to be a reicast problem.
                      Try to rename the .bin files (maybe also .raw files) to something like this:
                      before
                      after rename
                      track01.bin
                      Open the .gdi file with an editor of your choice and edit the filenames inside how you renamed the files before. save, close and try.
                      raiyoku 2 Replies Last reply Reply Quote 1
                      • raiyoku
                        raiyoku @abunille last edited by
                        This post is deleted!
                        • raiyoku
                          I edited it like this, I'll try in a seconds and tell you if it works 😉
                          https://image.noelshack.com/fichiers/2018/15/5/1523637653-capture.png
                          • raiyoku
                            @abunille @abunille @Substring I got the result.
                            When I launch the game, the dreamcast boot screen appears, I enter the date and hour, and when the game is supposed to start, I only have a white screen, and I can't do anything but unpluging my raspberry power cable. I have this issue the eu version and the us version.
                            • abunille
                              @raiyoku
                              on the fly i would say its a problem with your dc_boot.bin.
                              But i`m searching....
                                anyway, it's a non working image, try another .cdi or .gdi or .chd, no .cue
                                raiyoku 2 Replies Last reply Reply Quote 0
                                • raiyoku
                                  raiyoku @Substring last edited by raiyoku
                                  @substring tried with others gdi, I got a white screen each time
                                  • raiyoku
                                    @substring if you need more infos i made another script during the white screen. Hoping it will help finding the solution.
                                    On this it is an other crazy taxi rom I will send you a script with another game tomorrow if you want.
                                    https://file.ac/0snC0Rjp6Yg/
