    Problem with recalbox 18.03.30
    recalbox 18.03.30
    10326
    • Mr. Kilroy
      Mr. Kilroy @voljega last edited by
      @voljega @Substring
      @mr-kilroy april 20th
      Good afternoon! Today, on April 20, you said that the update will be today. But it is not, the release was postponed?
        voljega Banned @Mr. Kilroy last edited by
        @mr-kilroy it is always at 20:00 french time, and as they are just a few recalbox to updates, it's usually updated by "wave" you might receive it only tomorrow or sunday
        Mr. Kilroy 1 Reply Last reply Reply Quote 0
        • Mr. Kilroy
          @voljega Thank you! And the recalbox itself to be updated or should I use the console? Previously, though the button was "check the update"
            @mr-kilroy it will prompt you for an update when it is available for your recalbox
            Mr. Kilroy 2 Replies Last reply Reply Quote 0
              Substring @Mr. Kilroy last edited by
              @mr-kilroy you must format, and bathe your sd card in the blood of kittens you've just sacrificed. Kittens work best, trust me. I tried with female virgins, babies, baby panda ... Nothing is as good as kitten blood to make a successful recalbox upgrade !
              /me needs some holidays 😄
              • Mr. Kilroy
                @voljega Thank you. Tomorrow I'll try.
                @Substring An interesting way. If the standard does not work, I will certainly take advantage of your advice. Thank you! 😉
                • ShadowFrenchy
                  ShadowFrenchy @Substring last edited by ShadowFrenchy
                  @substring
                  Hi!
                  Just so you know, on recalbox 18.03.30 for odroid C2, the Sega 32x strangely disappeared from all menu, seems like it has been removed.
                  There's also a problem with the basic core for the mega CD, which can be resolved by using the Genesisplusgx core. There's also a topic with me and regalia about the c2 version, and how it may be fixed for both 32x and ps1, and even n64, as other cores on Lanka work best for these (picodrive for 32x, pcsx rearmed on ps1 and mupen64plus opengl for n64). As you say you are close to the Lanka programmers, do you think it would be possible to implement those from Lakka in recalbox with their consent? That would be just perfect!
                  Thanks for all your hard work man!
                  Ps: I'll install the new update and see if there is any change for the c2 and let you know...
                  • Mr. Kilroy
                    @voljega @Substring
                    Good afternoon! You were right, checked in reсalbox that the update is available. Downloaded 244 MB and updated. The problem is now in another, I'm from 8 am and 12 pm, I'm waiting for when to update. This 4 hours is only 60%. Why is it updated so long? I have a card for 16GB class 10, is the problem in it, or should it be renewed for a long time?
                      @mr-kilroy the upgrade itself ir the download ? Upgrades take about 25mins on my boards
                      • Mr. Kilroy
                        Mr. Kilroy @Substring last edited by Mr. Kilroy
                        @substring I downloaded quickly. But the update took from 8 am to 2 pm
                        Second question. Why in the recalbox manager you can upload images up to 300 MB, if the standard size of the PS1 disk is 700 MB?
                          @mr-kilroy because the manage is not stable enough to send bigger file and be sure that they are not corrupted, if you want to send bigger file, use WinSCP.
                          Even better, use external USB key or hard drive
                          • Mr. Kilroy
                            Mr. Kilroy @voljega last edited by Mr. Kilroy
                            @voljega
                            and change the way to the flash drive in the system settings? because the reсalbox does not pick up the flash drive as in other OS. 🙂
                            • ShadowFrenchy
                              ShadowFrenchy last edited by
                              Hi!
                              Upgraded from 18.03.30 to 18.04.20 on Odroid C2, also did a fresh install but both has the sega 32X disappeared on the menu (and yes, i do have the romsinstalled on the correct folder), it's also not there on the core selection menu of the emulators.
                              In fact, the folder is not event there on the install (i still have it because i have my roms stored on an external hdd.
                              Can we hope to have this patched for the next release? The mega CD is also broken with the pre-installed core, have to manually swap it to genesisplusgx to fix the problem and be able to launch a game...
                              It would be also great to have the psx and n64 fixed, the lakka cores for those work like a charm on the C2 (you can see the video i created for another topic here:
                              https://youtu.be/hKv1HhCOmYI ). Like i say in this topic (https://forum.recalbox.com/topic/13595/odroid-c2-psx-stuttering-choppy-and-sega-cd-iso-issue/31 ) the cores used on lakka are perfect on the C2, here's the info on them:
                              *PS1 Core PCSX ReARMed
                              Authors PCSX Team, notaz, Exophase
                              Permissions Dynarec
                              License GPLv2
                              Supported extensions bin, cue, img, mdf, pbp, toc, cbn, m3u
                              Firmwares
                              scph5500.bin (md5) 8dd7d5296a650fac7319bce665a6a53c
                              scph5501.bin (md5) 490f666e1afb15b7362b406ed1cea246
                              scph5502.bin (md5) 32736f17079d0b2b7024407c39bd3050
                              *Sega 32X core PicoDrive
                              system name Sega 8/16-bit + 32X (Various)
                              Authors notaz, fdave
                              Permissions dynared_optional
                              License MAME
                              Supported extensions bin, gen smd, md, 32x, cue, iso, sms, 68k
                              Firmwares
                              bios_CD_U.bin (md5) 2efd74e3232ff260e371b99f84024f7f
                              bios_CD_E.bin (md5) e66fa1dc5820d254611fdcdba0662372
                              bios_CD_J.bin (md5) 278a9397d192149e84e820ac621a8edd
                              *Core name Mupen64Plus OpenGL
                              Core label Nintendo 64 (Mupen64Plus)
                              System name Nintendo 64
                              Authors Hacktarux, Mupen64Plus Team
                              License GPLv2
                              Supported extensions n64, v64, z64, bin, u1, ndd
                              Do you think it would be possible to have them on Recalbox? Substring said that he's quite close to lakka's developpers... Picodrive would work like a charm for the 32x games. What's strange is that recalbox also use PCSX ReARMed, maybe it's a compilation problem... I remember Lakka having the same problem on PSX with the core at launch, but it has been long fixed since then.
                              Thanks guys!
                              PS: I'll soon post a video of how it runs on the C2 actually, it's really choppy like regalia said, so you can see for yourself.
                              Hope to see
                              100.2k
