    curl piboxy (recalbox)
    curl piboxy recalbox
    1873
    • recallbox
      recallbox last edited by
      hey
      i cant install drive for piboxy case to safe shutdown
      here
      recallbox 1 Reply Last reply Reply Quote 0
      • recallbox
        recallbox @recallbox last edited by recallbox
        @recallbox
          OyyoDams Staff @recallbox last edited by
          @recallbox this script is for Retropie, it cannot work like that on Recalbox OS. Do you have good linux skills ?
          • recallbox
            @oyyodams
            thx for replay
            unfortunately i don't have any Linux skills and i work on Windows
            look for any way to enable "curl" on Recalbox, cuz i don't like retropie
              voljega Banned @recallbox last edited by
              @recallbox it's not possible
                @recallbox
                wiring package is missing on recalbox but @OyyoDams will see soon to add this.
                for later you need to do this :
                create installpiboxy.sh file with notepad++
                copy/paste
                #!/bin/bash
                hostname=$(hostname)
                if [[ "$hostname" == "RECALBOX" ]];then
                echo "Installing RECALBOX Piboxy Driver..."
                gpio readall > /dev/null 2>&1
                if [ $? -eq 0 ]; then
                mkdir -p /recalbox/share/system/bin/
                wget -O /recalbox/share/system/bin/remoteswitch http://piboxy.com/download/remoteswitch
                chmod a+x /recalbox/share/system/bin/remoteswitch
                echo "/recalbox/share/system/bin/remoteswitch -r 17 -s 18 -n 4 &" > /recalbox/share/system/custom.sh
                chmod a+x /recalbox/share/system/custom.sh
                mount -o remount -rw /boot
                if grep -q "^dtparam=i2c_arm=off" /boot/config.txt; then
                	sed -i "s|^dtparam=i2c_arm=off|dtparam=i2c_arm=on|" /boot/config.txt &> /dev/null
                elif grep -q "^#dtparam=i2c_arm=on" /boot/config.txt; then
                	sed -i "s|^#dtparam=i2c_arm=on|dtparam=i2c_arm=on|" /boot/config.txt &> /dev/null
                else
                	echo "dtparam=i2c1=on" | tee -a /boot/config.txt &> /dev/null
                	echo "dtparam=i2c_arm=on" | tee -a /boot/config.txt &> /dev/null
                fi
                if grep -q "^vc_i2c_override=0" /boot/cmdline.txt; then
                	sed -i "s|^vc_i2c_override=0|vc_i2c_override=1|" /boot/cmdline.txt &> /dev/null
                else
                	echo -n "bcm2708.vc_i2c_override=1" >> /boot/cmdline.txt
                fi
                sync
                mount -o remount -r /boot
                if ! [ -e /etc/modprobe.d/raspi-blacklist.conf ]; then
                touch /etc/modprobe.d/raspi-blacklist.conf
                fi
                sed /etc/modules.conf -i -e "s/^#[[:space:]]*\(i2c[-_]dev\)/\1/"
                if ! grep -q "^i2c[-_]dev" /etc/modules.conf ; then
                printf "i2c-dev\n" >> /etc/modules.conf
                printf "i2c_bcm2708\n" >> /etc/modules.conf
                fi
                /recalbox/scripts/recalbox-save-overlay.sh
                modprobe i2c-dev
                modprobe i2c_bcm2708
                sync
                echo "Rebooting to finish installation"
                sync
                sleep 2
                reboot
                save and transfert in share folder, but
                via putty
                chmod +x /share/installpiboxy.sh
                bash /share/install.sh
                recallbox 1 Reply Last reply Reply Quote 1
                • recallbox
                  recallbox @acris last edited by
                  @acris
                  Great!
                  thx bro
