    Solved 17.12.02 to 18.03.30?
    17.12.02 18.03.30
    2829
    • Marcos Breviglieri
      Marcos Breviglieri last edited by
      Is there any way to upgrade from version 17.12.02 to 18.03.30? Because the system shows there are no updates available.
        OyyoDams Staff @Marcos Breviglieri last edited by
        @marcos-breviglieri do you have a file named uuid in your system folder?
        Marcos Breviglieri 1 Reply Last reply Reply Quote 0
          Marcos Breviglieri @OyyoDams last edited by
          @oyyodams said in 17.12.02 to 18.03.30?:
          Yes the file is there. This is his content:
          3ead2903-bec3-45df-9fdb-a7df01b13840
          OyyoDams Substring 2 Replies Last reply Reply Quote 0
            OyyoDams Staff @Marcos Breviglieri last edited by OyyoDams
            @marcos-breviglieri great. Can you connect to ssh, and give me the result of this command:
            bash -x /recalbox/scripts/upgrade/recalbox-upgrade.sh‛
              Substring @Marcos Breviglieri last edited by
              @marcos-breviglieri donyou have enough space to download the update ? It thenlog from the prevoous updates not showing errors ?
                Resolved after releasing placeholder on partition with command tune2fs
                • Mr. Kilroy
                  Mr. Kilroy last edited by
                  Hi! And you can learn more about updates. Earlier though the button was for checking.
                  From the written did not understand anything: ( also commands to enter somewhere...
