    [WIP] THEME ALEKFULL (for Recalbox 18.03.16)
    Themes & Interface
    [wip] theme alekfull recalbox 18.03.16
    37
    75
    80691
    • Choum
      Choum last edited by
      Is it normal this white awfull background on the new version ?
      alt text
      fagnerpc 1 Reply Last reply Reply Quote 0
      • Dragu
        @fagnerpc
        Perhaps too much changing ? Red text is not really an alternate for white. 😉 The problem was more that the text was partly transparent. But german syntax now ok.
        PC logo is a little ugly, but I found something in your files that I cropped and adopted :
        alt text
        So for me, just to resume, old version was perfect, with no transparent letters on selection and correct special characters and little more neutral DOS logo.
        I must also say, the sound is not an option for me, as with DAC card I cannot regulate the volume in ES. And with time, it will become nerving. So I think not really something wanted by most.
        • Dragu
          The responsable for the bad reading and the missing special characters was the font Perforama.otf. So I replaced also in former version 040118 Perforama.otf by Roboto-Medium.ttf in the systemview vertical.xml, vright.xml, vrlow.xml.
          And excuse for the digging in your craftwork. 😉 But its anyway best.
          • ViRuS-MaN
            ViRuS-MaN last edited by
            i just install the last version but the pic dont appear for all systems
            • Caglisto
              Caglisto last edited by
              @gwyllion said in [WIP] THEME ALEKFULL (for Recalbox 18.03.16):
              @nexusone13 and oddyssey to o2em
              That's right is Missing the Odyssey2. Recalbox folder name is o2em. Follow the Link to the video game. Could you please do that for us?
              Thanks for the awesome work bro! Cheers.
              https://www.google.com.br/search?q=odyssey2&rlz=1C1CHBD_enNZ769NZ769&tbm=isch&source=lnt&tbs=isz:l&sa=X&ved=0ahUKEwiw4IDk36DaAhUIS5AKHS_zBSwQpwUIIA&biw=1920&bih=900&dpr=1#imgrc=qOQLusZ_UgY2JM:
              • ViRuS-MaN
                no news for this fantastic theme ???
                • Dragu
                  @ViRuS-MaN
                  If I read things like "the consoles overlap in wheel mode.." I would also stop. Because if somebody arrive to cut rectangular pieces of cake in an round pie, he is Hudini. And song wish is the same b.llsh.. So very difficult to satisfy everybody. The existing files and backgrounds and xml files are anyway easy to modify to own wishes.
                  tikiandskull 1 Reply Last reply Reply Quote 0
                  • tikiandskull
                    tikiandskull @Dragu last edited by
                    @dragu ce que je voulais dire, mais je crains que Google n'ait traduit ça "brusquement", c'était juste de savoir si le pas entre les images de la roue pouvait être modifié pour que les images ne se chevauchent pas. Sinon ce thème est très cool. D'ailleurs il est sur ma recalbox. ☺️
                    • ViRuS-MaN
                      et pour le probleme quand je mets la derniere version tous mes arrieres plan son blanc et la roue aussi , je vois rien du tout
                      tony37 1 Reply Last reply Reply Quote 0
                      • tony37
                        tony37 @ViRuS-MaN last edited by
                        @virus-man j'ai eu le meme soucis, probleme resolu, il y avait un sous dossier dans le theme.
                        • ViRuS-MaN
                          ViRuS-MaN last edited by ViRuS-MaN
                          comment tu a fait ???
                          moi je vois pas de sous dossiers , la je comprends pas
                          • recalfred
                            recalfred last edited by
                            moi aussi , car moi chaque theme apparaît sauf celui de odyssée 2 et pc engine cd , cela vient d'où ?
                            • fagnerpc
                              fagnerpc Theme moderator @Choum last edited by
                              @choum said in [WIP] THEME ALEKFULL (for Recalbox 18.03.16):
                              alt text
                              Yes, that's the default view
                              You can change the color in the Theme Settings menu or simply delete the square.png files inside the assets folder
                              ARCADE ALEKFULL
                              • fagnerpc
                                fagnerpc Theme moderator @Dragu last edited by
                                @dragu said in [WIP] THEME ALEKFULL (for Recalbox 18.03.16):
                                Perforama.font has no special characters so I changed it in this new version.
                                I didn't realize it, because I tested here with the special characters for Portuguese (i'm brazilian) and there was nothing wrong
                                But thanks for realizing the missing special characters.
                                @fagnerpc
                                alt text
                                Well, the white text is still there as option - just change in the Theme Settings menu to 'Blue/ White Menu Text' or 'Grey/ White Menu Text'
                                The PC logo is more neutral... i also made this DOS logo - just rename the dos.png to pc.png on the logo folder
                                About the sound: just delete the lines below (80 to 82) on theme.xml and save
                                <sound name="bgsound">
                                <path>./assets/sounds/$system.ogg</path>
                                </sound>
                                ARCADE ALEKFULL
                                • fagnerpc
                                  fagnerpc Theme moderator @fagnerpc last edited by
                                  @virus-man said in [WIP] THEME ALEKFULL (for Recalbox 18.03.16):
                                  Hey @ViRuS-MaN , how ur doing?
                                  I'm kind of busy right now ... I went back to my job so I have little free time at the moment
                                  I'm also working on a version for Recalbox of the wonderful theme made by SuperMagicom called Nostalgic
                                  I have a lot of work to do to align all the scrapes in the right place, but everything is going well
                                  • alt text
                                    alt text
                                    alt text
                                  ARCADE ALEKFULL
                                  • recalfred
                                    bonjour j'ai installé le thème alekfull avec la dernière mise a jour de recalbox, et tout marche sauf que j'ai ni le logo odyssée 2 , ni l'image , ni la musique, pourtant les fichiers sont bien présent comment remédier au problème ? merci
                                    • SylGaud
                                      SylGaud last edited by SylGaud
                                      Thnaks @fagnerpc for your them!!
                                      As you can see, image is deformed on 4:3 screens:
                                      Obviously it is developped for wide screens --> Is there a way to get it for 4:3 screens?
                                      Thanks 🙂
                                      • recalfred
                                        j'ai résolu le problème , il suffisait de remplacer dasn les fichiers sounds, art, art 2, logo 1 logo 2, le o2em par odyssée 2 , voilà et ça remarche
                                        • fagnerpc
                                          fagnerpc Theme moderator last edited by
                                          New theme i'm working on:
                                          PREVIEW HERE
                                          alt text
                                          alt text
                                          ARCADE ALEKFULL
                                          voljega fagnerpc 2 Replies Last reply Reply Quote 3
                                            voljega Banned @fagnerpc last edited by voljega
                                            @fagnerpc I would remove mention of facebook and instagram, and Recalbox square in the upper right corener, it's already very heavy to the eyes
                                            101.0k
