    Nintendo Switch Pro Controller
    nintendo switch
    9065
    • RealAzyria
      RealAzyria last edited by
      It's been awhile since I came to the forums for help or to ask a question, I just got a Switch and next week I'll be getting a pro controller and since I really like the feel better the ps4 controller I was planing on using it for the my raspberry pi (recalbox) my question is am I able to use it with recalbox? Is there any problems with the analog sticks and buttons? I know the Motion controls are out of the question so I know I won't be able to play Kirby tilt and tumble and that one Warioware game which sucks. But will everything else work will I have problems. I just know when I play ps1 games I need the analog sticks for most games.
      lackyluuk 1 Reply Last reply Reply Quote 0
      • lackyluuk
        lackyluuk Translator @RealAzyria last edited by
        @realazyria
        According to this list, the official Switch Pro Controller works fine: https://github.com/recalbox/recalbox-os/wiki/Compatibility-(EN)
        RealAzyria 1 Reply Last reply Reply Quote 1
        • RealAzyria
          RealAzyria @lackyluuk last edited by
          @lackyluuk well I was just asking because when I looked it up people were having problems with it on retropie. I know recalbox is different in many ways but I just wanted to make sure.
          lackyluuk roman126 2 Replies Last reply Reply Quote 0
          • lackyluuk
            @realazyria
            If you get one anyway, then just try it out 🙂 I don't own one myself, I just refer to the list
            • roman126
              roman126 @RealAzyria last edited by
              @realazyria I have a wii u pro controller and it works perfectly, wired or wireless!
              • ToastMan
                ToastMan last edited by
                I tested, press for 10 seconds de sync button of procontroller
                Go to pair controllers, and select it PRO Controller from the List.
                when i reset donset save the pair.
