    Emulationstation does not revert back to it's original resolution
    emulationstatio resolution help
    2996
    • granderjoree
      granderjoree last edited by granderjoree
      Hello!
      I have a raspberry pi 3 model B and updated to the latest Recalbox update.
      When I start a game for example in Playstation which I change the resolution to 640 x 480, when I exit back to emulationstation, the resolution in emulationstation also changes. I don't know what's wrong.
      My global videomode is set to default (global.videomode=default)
      Attached here are some of the pictures for reference.
      Please help.
      (This is the normal resolution of the emulationstation)
      (When I play a game with a resolution of example 640 x 480 like this)
      (When I exit, the emulationstation also takes the resolution of the previous game that I played which looks like these)
        Known problem, solution has been given several times as a manual fix until we make a new release
        granderjoree 1 Reply Last reply Reply Quote 0
        • granderjoree
          granderjoree @Substring last edited by
          @substring What's the solution? Please point me to a link of the solution. Thanks!
            Substring @granderjoree last edited by
            @granderjoree check my posts, thank you
            • granderjoree
              @substring It's fixed! I followed your instructions on your previous posts. Thanks @Substring! Ur da best!
              tekkenism 1 Reply Last reply Reply Quote 0
              • tekkenism
                tekkenism @granderjoree last edited by
                @granderjoree I have the same problem and couldn't find the solution among Substring's older posts. Can you tell what you tried? Thanks.
                idarius 1 Reply Last reply Reply Quote 0
                • idarius
                  idarius @tekkenism last edited by idarius
                  @tekkenism https://forum.recalbox.com/topic/13256/18-03-16-screen-resolution-problem/13
                  mount -o remount, rw /
                  rm /usr/lib/python2.7/site-packages/configgen/utils/videoMode.pyc
                  wget -O /usr/lib/python2.7/site-packages/configgen/utils/videoMode.py https://gitlab.com/recalbox/recalbox-configgen/raw/0bc27e90248812a62f80de94810434acbf7ac418/configgen/utils/videoMode.py
                  tekkenism 1 Reply Last reply Reply Quote 1
                  • tekkenism
                    tekkenism @idarius last edited by
                    @idarius Thank you so much!
                    • idarius
                      @tekkenism thx to @Substring 😉
