    Mario Kart 64 - too fast with 4 Players
    Emulator Arcade/PC/Console
    mario kart too players
    9180
    • riley91
      riley91 last edited by
      Hey Folks,
      i'm happy so far with my recalbox on my pi 3! All is running well...
      But when playing Mario Kart 64 for the N64 the game is playing at maybe double or triple Speed! 1 and 2 Player-matches are working finde. But with 4 Players its so fast even with 50ccm it's no fun at all. I don't know what the problem might be. Google didn't tell me any answer or solution... I'm just a beginner and happy i managed to get 4 Controllers working at the same time šŸ˜‰
      Any help is appreciated!
      • riley91
        No one who can help? šŸ˜ž
        • joinski
          joinski last edited by joinski
          That Mario Kart 64 with 4 Players on Recalbox runs way too fast has always been like this, as far as i can remember (i think even with version 3.3.0 beta17 I had already noticed this).
          But it is only with 4 Players in Versus mode. In 4 player Battle Mode the speed is normal.
          And in my opinion it isn't that bad. It makes so much more fun at high speed with 4 Players in Versus Mode (especially the Koopa Troopa Beach map).
          Just give it a few tries and you and your friends will enjoy it šŸ˜‰
          riley91 1 Reply Last reply Reply Quote 0
          • riley91
            riley91 @joinski last edited by
            @joinski said in Mario Kart 64 - too fast with 4 Players:
            Thanks for your help, but we tried it a few hours and were veeery annoyed... i know it is only in 4 Player versus mode. But thats the most played mode beside 2 Player mode (which runs at a fine and normal Speed šŸ˜‰ )
            i read in another forum, that there's a solution via cheat... but i don't know how to use it šŸ˜ž it seems to solve the Problem.
            http://www.emutalk.net/threads/33626-Help-Mario-Kart-Running-too-fast!!/page2
            Multiplayer speed fix
            81001C90 240A
            81001C92 0002
            81001C94 240A
            81001C96 0002
            81001A38 2409
            81001A3A 0002
            81001A3C 2409
            81001A3E 0002
            anybody who knows how to use this?!
            • riley91
              I'm begging you... :'-(
                paradadf Staff @riley91 last edited by paradadf
                @riley91 try wirh Glupen64 core by pressing select on the game lost, edit metadata and chnging the first two entry from default to libretro and glupen. Mupen64plus standalone needs a b*mp to support a configuration ini (I think) which should resolve the speed issue (if Iā€˜m not wrong). You can try to use that cheats on the libretro port (glupen64 as mentioned before) too. No idea where the cheat file is located though.
                See for instace:
                https://github.com/mupen64plus/mupen64plus-core/pull/203
                • riley91
                  riley91 @paradadf last edited by
                  @paradadf said in Mario Kart 64 - too fast with 4 Players:
                  See for instace:
                  Thank you so much, speed is at normal now! Finally...
                  BUT... all my controll settings from mupen64plus.cfg are lost.. of course because i use a different emulator now. How do i set it up now?! I only know for mupen64plus to edit the config file from mupen64plus.
                    @riley91 you can do it from the retroarch menu HK+B. There is a wiki entry about that.
                    • riley91
                      Yeah ok, got that, but how to configure Z button?! The retroarch menu doesn't have the z button when configuring the controls... maybe you can show me the wiki?!
                        voljega Banned @riley91 last edited by
                        @riley91 really ? The wiki is under your eyes on top of the page
                        • riley91
                          riley91 @voljega last edited by
                          @voljega said in Mario Kart 64 - too fast with 4 Players:
                          Not so helpful sorry, instead you could've just posted the link..
                          https://github.com/recalbox/recalbox-os/wiki/Configure-N64-controllers-(EN)
                          I can only find the howto for mupen64plus but NOT for retroarch...
                          • riley91
                            Ok found out that z button has to be assigned to L2 button (yeah self explaining..) but now Mario kart won't start with libretro... I'm quite fed up...
                            • agahowa23
                              agahowa23 last edited by
                              I got to say that's strange man. When I play Mario Kart 64 with 4 players the game runs fine, maybe a little laggy sometimes, I have never experienced speed issues. Try changing emulators or cores, but not changing controller configs. Use the default controller configuration (L2 as Z button). I would reinstall Recalbox in your SD card since you already altered your configs. Libretro core usually fixes any problem, for example, use Libretro if you wanna run Mario Party, it works wonderfully!
                              • agahowa23
                                As for the cheats you have, I have never tried cheats on Recalbox, but you should know you can activate them only if you are using the Libretro core via the Retroarch menu (HK + B). I cannot give you more help than that because I wouldn't know how to activate them until I try it myself. But use the Libretro core, open the Retroarch menu, open Quick Menu and then Cheats, activate the cheat you want and apply your changes. I think cheats must be on .cht extension, I really don't know and I really don't know how to do that... sorry, but I hope I helped.
                                • riley91
                                  changing the emulator to "n64" and keeping the core as mupen64 did the thing... works like a charm. Easy and simple... already had much fun with 4 players at normal speed!
                                  thx a lot!
                                  Copyright Ā© 2021 recalbox.com
