    [Resolved] Black border despite overscan
    [resolved] border despite overscan
    • failix
      failix last edited by
      Hello, I installed today Recalbox on my Raspberry Pi 2. Everything works fine but I can only use a part of my screen (an Acer V193 B) : (Image is attached) The screen is connected with a hdmi-to-DVI-Adapter. Changing the overscan-Settings in the config doesn't solve the problem of the black margin (on the left of the pink line). I have already reinstalled Recalbox but again the same issue. Changing the settings of the screen also doesn't help. It sounds a bit like https://github.com/digitalLumberjack/recalbox-os/issues/266 I wonder if anybody has a solution or a idea what I could do? Thank you very much!   With best regards Felix
      • karuzo
        karuzo last edited by
        Maybe your HDMI output is to hi for your screen. You have to reduce the resolution in the config.txt. Here is a little explanation. https://www.raspberrypi.org/documentation/configuration/config-txt.md Try to set a non 16:9 Format resolution. I Hope that helps
        • digitaLumberjack
          First try to change the driver : https://github.com/digitalLumberjack/recalbox-os/wiki/Connect-your-recalbox-to-a-DVI-screen-(EN) Next if it still fail, try other resolutions 🙂 You have a second issue, your power supply is not providing enought power (rainbow square)
          • failix
            Changing the driver solved the issue! Thank you very much! I'll get another power supply for a usb-port/a powered usb-hub, didn't know that the rainbow square indicates a lack of power. 🙂
