    New FBCP instructions
    fbcp instructions
    3421
    • bigbear
      bigbear last edited by
      Hi all
      I tried running through the instructions today to get an adafruit 2.8" TFT going.
      I found a lot of detailed instructions but found that some steps i.e. etc/init.d wasn't needed as there was already a script there.
      The FBCP executable was already in /use/bin/
      I ended up making the suggested changes to the boot and recalbox config files.
      Given all this I still couldn't get the screen to work properly.
      I does show the initial recalbox splash image but after that the screen goes white.
      Are the instructions being updated or is someone able to provide me with some guidance?
      Cheers
      Gerard
        Substring @bigbear last edited by
        @bigbear let's try to summon @ian57 ...
        • ian57
          ian57 Staff last edited by
          @bigbear @Substring Yes I need to rewrite the howto, because lots of things are now embedded in Recalbox. Need time to do that
          but briefly :
          1. modify the /boot/config.txt to fit to the resolution of your screen and the right overlay
          2. in recalbox.conf juste activate the fbcp support and restart
          ## fbcp FrameBuffer Copy Program
          ## For small TFT screen on GPIO and SPI
          ## See https://github.com/recalbox/recalbox-os/wiki/Utility---Use-of-fbcp-for-small-TFT-screen-%28EN%29 for details
          ## Needed for Waveshare 3.2" 3.5" TFT screen, 2.8" Adafruit screen
          ## See https://github.com/recalbox/recalbox-os/wiki/TFT-Screen-SPI-Bus-%28EN%29
          ## for support and configuration details needed by /boot/config.txt
          system.fbcp.enabled=1
          Hope this helps
          • bigbear
            Hi @ian57 - thanks for getting back to me.
            I modified system.fbcp.enabled=1 as suggested.
            I also made the following changes to recalbox.conf:
            #global.videomode=DMT 87 HDMI
            global.videomode=default
            #global.ratio=auto
            global.ratio=4/3
            I also added the following to the end of /boot/config.txt:
            dtparam=spi=on
            dtparam=i2c1=on
            dtparam=i2c_arm=on
            #forcing HDMI output at TFT screen resolution to be able to make the FB copy
            #resolution configuration
            hdmi_force_hotplug=1
            hdmi_cvt=320 240 60 1 0 0 0
            hdmi_group=2
            hdmi_mode=87
            # working config for speed
            # 900 Mhz -> 48000000
            # 1Ghz -> 35000000
            #modification of the speed
            dtoverlay=pitft28-resistive,rotate=90,speed=22000000,fps=60
            This pretty much matched what I had done before and I'm getting the same results.
            The new xmas boot vid starts but just at the point where the xmas tree is expected to show the screen goes white and doesn't change.
            I've tried a RetroPie install and it worked so I know that the screen is working ok.
            Do you have any suggestions on what I might try next?
            Cheers
            Gerard
            bigbear 1 Reply Last reply Reply Quote 0
            • bigbear
              bigbear @bigbear last edited by
              Hi @ian57 - I figured out what the problem was.
              It probably helps if I provide a bit more background info. I'm working on a PiGRRL 2.0 kit and didn't want to use RetroPie.
              Part of the kit uses a PiGRRL gamepad which effectively piggy backs on the GPIO pins that the AdaFruit TFT uses.
              In the recalbox.conf file I had set controllers.gpio.enabled=1 assuming that this was needed to allow the PiGRRL gamepad to work properly.
              Changing it back to 0 allowed the screen to work as expected.
              # ------------ D2 - GPIO Controllers ------------ #
              ## GPIO Controllers
              controllers.gpio.enabled=0
              Now I just need to figure out how to make the Gamepad work.
              Gerard
              • ian57
                @bigbear thanks for your feedback. Yes some GPIO are use by the screen and the the mk_arcade kernel module. SO if both are activated... the screen driver craches.
                101.4k
