    Laggy Wireless Mouse
    laggy wireless mouse
    • roman126
      roman126 last edited by roman126
      is there a fix by putting an entry in the recalbox.conf for a laggy wireless mouse?
      In Retropies cmdline.txt, you just added the following;- usbhid.mousepoll=0
      and it sorted the problem, is there a similar type of fix in Recalbox?
        try the same thing
        roman126 1 Reply Last reply Reply Quote 0
        • roman126
          roman126 @acris last edited by
          @acris i did, didn't appear to make much difference....
