    Problem getting X-Arcade Tankstick Trackball working in MAME- Please help
    GamePad/GPIO/USB encoder
    getting x-arcade tankstick trackball mame
    5019
    • implode99
      implode99 last edited by
      Guys,
      I have a X-Arcade Tank stick with trackball. When plugged into my PC it acts as a mouse. When plugged into Recalbox. I cant seem to get it to work at all. Joysticks and buttons are fine. Can anyone help ? I would love to play Cabal , centipede , and arknoid with it. I have both USb cables plugged in also btw
        Substring @implode99 last edited by
        @implode99 hi
        Imn not sure those cores handle mices. Anyway, it's probably a good thing to check the retroarch inputs. I have a tankstick too, and never ever tried to make the mouse part work
        implode99 1 Reply Last reply Reply Quote 0
        • implode99
          implode99 @Substring last edited by
          @substring its wierd. I had centipede working for very short time with mame4all (read it was supporting mouse). But some reason it stopped and i cant get it working again . Tired every combo, looked in .cfg files etc
            @implode99 a simple look at core inputs in the retroarch options is necessary
            • implode99
              @substring though the .config file or the GUI interface ?
                @implode99 the gui i guess. Retropie has a wiki on it, but this may be colplicated tonapply tonrecalbox for nulerous reasons. But you may get the general idea
                • implode99
                  @substring said in Problem getting X-Arcade Tankstick Trackball working in MAME- Please help:
                  Retropie
                  I am kind of surprised its not implemented as standard within the configuration for X-Arcade sticks, since they are so popular( I say this regretfully) .
                    @implode99 because no one ever asked so far for any help on this ? And anyway mouse support in retroarch is very new
                    • implode99
                      @substring ah ok. Well I will do some more tinkering. I found this page. I will try some of the ideas:
                      https://github.com/RetroPie/RetroPie-Setup/wiki/Spinners,-Trackb***s,-Lightguns,-and-other-Mouse-Devices
                        @implode99 t's the one I meant. I should be able to do some testings this weekend if you need help
                        • implode99
                          @substring thats great thanks. I will keep you posted. I also found this link might be helpful -
                          https://retropie.org.uk/forum/topic/14283/getting-trackball-to-work-with-mame/13
