    Parsec on RB?
    parsec
    • stigzler
      stigzler last edited by
      This looks good:
      https://www.youtube.com/watch?v=sjO95WmyCc0
      chances of integrating to rb?
      Substring 1 Reply Last reply Reply Quote 1
        Substring @stigzler last edited by
        @stigzler No chance, it needs X11 which we don't support in Recalbox. Unless you want your pi to emulate like a tractor
        • stigzler
          lol. OK - no tractors.
            @stigzler but we have Moonlight, which is not bad at all
            • Norde
              Norde last edited by
              I answer a little late (but as I just arrived on the forum then ...).
              Unfortunately, Moonlight is only compatible with Nvidia cards. Pa**ec is the only viable solution for Radeon / AMD cards ownners.
              About Pa**ec, I tested it under retropie: performances are bad and system updates can sometimes be problematic.
              The best is to realize a dual boot "Retropie / Raspbian lite" with the raspbian only dedicated to Pa**ec (automatic launching at start, drivers for joysticks, Wake on LAN to computer, etc ...).
              If some people are interested, I will offer a step-by-step guide for Pa**ec's friendly use (just give me a month to test my installation and find any problems
              Boards : Rpi1 B+, Rpi2 B, Rpi3 B, Rpi3 B+
              Controllers : Xbox One S controller, PS1 controllers
              Case : Superpi case Retroflag
