    Mame Samples folder
    Emulator Arcade/PC/Console
    mame samples forldwf
    • thesnable
      thesnable last edited by thesnable
      Hello
      where do it correctly place mame samples?
      thanks
        Hello
        readme.txt in folder /roms/mame must be help
        Gwyllion 1 Reply Last reply Reply Quote 0
        • Gwyllion
          Gwyllion @acris last edited by
          @acris said in Mame Samples folder:
          Hello
          No samples mention there:
          "## RECALBOX - SYSTEM MAME ##
          Put your mame roms in this directory.
          Rom files must have a ".zip" extension.
          Recalbox is using libretro mame2003 as default core. So, compatible roms must come from set 0.78
          The libretro core imame4all, based on a 0.37b5 mame version, is also included in recalbox.
          So, if you want to use this core, instead of the default one, you must edit your recalbox.conf file following instructions of this page :
          https://github.com/recalbox/recalbox-os/wiki/recalbox.conf-(EN)
          You can use clrmamepro available at http://mamedev.emulab.it/clrmamepro/ and use the .dat file in clrmamepro directory to check your roms."
          • RustyMG
            RustyMG last edited by RustyMG
            Hi,
            Assuming your using Mame2003, the zip files containing samples go in Recalbox/share/bios/mame2003/samples
            Sinclair ZX Spectrum 48k "dead flesh" keyboard, Commodore 64, Amiga A500, Amiga A1200, CD32, PC Engine, PS1, PS2, PSP, Nintendo DS, Dreamcast, Wii, XBox 360, Xbox One-X, Pi2, Pi3, Pi4 owner, ARRM contributor ( http://jujuvincebros.fr/wiki/arrm/doku.php ).
