    Keybinding are not saving inside retroarch
    keybinding are saving inside retroarch
    8138
    • retropiguy
      retropiguy last edited by retropiguy
      I was having problems with Kodi so I did a fresh install of Recalbox. I set everything up, loaded all my roms, everything works great, besides remapping key bindings inside retroarch. For NES, gameboy and gba I would swap the A and Y buttons by remapping them and saving the settings. With this fresh install, when I save within the keybindings menu, it does nothing, I exit and reload the rom and the keybindings I set are back at default. And when I change key bindings and save the core, it REVERTS the keybindings back to their defaults! I am at a loss and going insane. What is the problem? Appreciate any input.
      • Dragu
        Dragu Banned last edited by
        @retropiguy
        Normal way, after you enter Retroarch
        ---> Quickmenu
        ---> Controls
        ---> "Change your buttons assignation"
        ---> Select "Save Game Remap File" or "Save Core Remap File"
        ---> go back
        ---> "Save Game Overrides" or "Save Core Overrides"
        and leave Retroarch
        From now on you should see at the beginning of games small yellow line "Game remap file loaded" or "Core remap file loaded"
        There may be an issue. That the quickmenu point "Controls" dont exist under the emulator that you have running under SNES. I was having such issue. But if you change to an SNES emulator that accept it, you can change everything like mentioned before and after switch back.
        Some weird things in Retroarch.
        retropiguy 1 Reply Last reply Reply Quote 1
        • Dragu
          @retropiguy
          I was writig more in another part of the forum about :
          Dragu 18 days ago
          Je pense que j'ai trouvé, il y a une erreur dans retroarch.
          Dans le core default NES il n y a pas de sélection "Controls" au niveau de Quick Menu. Et je comprends que je suis pas le seul ayant eu des problèmes ici. Alors, il faut d'abord sélectionner un autre émulateur soit Libretro core: Nestopia, ici la sélection "Controls" existe.
          On change B en A/ Turbo B en X/A en B/Turbo A en Y.
          Après on sélectionne "Save core remap File" et il la sauve sous
          /recalbox/share/system/.config/retroarch/config/remaps/Nestopia/Nestopia.rmp
          Maintenant on change manuellement /Nestopia/Nestopia.rmp en /FCEUmm/FCEUmm.rmp
          • retropiguy
            retropiguy @Dragu last edited by
            @dragu
            THANK YOU SIR! I successfully swapped the buttons and saved them by switching the emu's core. Which is strange because on my first recalbox setup, I did not have to do that. On my first setup, I remember the quick menu controls option with the ability to swap keys being there without changing anything. Thanks again.
              Substring @retropiguy last edited by
              @retropiguy if you were wondering about swapping A and B functions inside RA, you could just change the option in the retroarchcustom.cfg file
              retropiguy 1 Reply Last reply Reply Quote 0
              • retropiguy
                retropiguy @Substring last edited by
                @substring said in Keybinding are not saving inside retroarch:
                retroarchcustom.cfg
                I remember trying this option in the past with no luck, which resulted in me just binding them how I wanted. Can you shed some light on it? Which emulators does it affect?
                  Substring @retropiguy last edited by Substring
                  @retropiguy It wasn't working in the past AFAIR, but now it does work as we have enabled it to make A and B h**ogeneous between RA and ES
                  see https://gitlab.com/recalbox/recalbox/blob/master/board/recalbox/fsoverlay/recalbox/share_init/system/configs/retroarch/retroarchcustom.cfg.origin#L52
                  • Dragu
                    @Substring
                    C'est drôle, j'ai cette ligne aussi dans mon retroarchcustom.cfg, mais elle n'a pas d'effet chez moi sur le swap des touches A/B X/Y. Je viens juste de réessayer en renomant FCEUmm en xxxxxx. Et plus de Swap. 😉
                      Substring @Dragu last edited by
                      @dragu non ca swap uniquement A et B dans le menu RA, pas ingame
                      • Dragu
                        @Substring
                        Aaah, ok. Compris. On en apprend tous les jours. 😉
                        101.4k
