    Force intel GPU ?
    force intel gpu
    • crackwindobe
      crackwindobe last edited by
      Hello
      On my x64 pc i have a Geforce 1060 who is not yet supported by Recalbox, and in my CPU an Intel UHD Graphics 630 GPU who is supported by recalbox.
      But went i start, recalbox is using Nvidia. Is there a way to force Recalbox using my Intel GPU ?
      Thanks
      Fourch joinski strodown 3 Replies Last reply Reply Quote 0
      • Fourch
        Fourch @crackwindobe last edited by
        @crackwindobe I have an Intel UHD 630 and the menu is laggy (5fps), wrong resolution and games lag.
        On the compatibility board, it seems Intel HD 630 works, but probably there is a driver difference with the UHD version.
        • joinski
          joinski @crackwindobe last edited by OyyoDams
          @crackwindobe
          you have to remove the 1060 from your system (take it out of the PCIe-Port).
          • strodown
            strodown @crackwindobe last edited by
            hi @crackwindobe test this image with gpu nvidia its a image of recalbox with nvidia driver for best compatibilty
            https://forum.recalbox.com/topic/15914/recalbox-pc-x86_64-avec-les-drivers-nvidia
            Recalbox X86_64 :
            X-Arcade
            Lightgun Mayflash Dolphin-bar
