    4-Player-Support for SNES-Games?
    snes-games
    11430
    • 5t4m
      5t4m last edited by
      Hi all, Nice work! I am looking forward to upgrading my old Pi B with Retropie to Pi B2 and Recalbox OS. However, is it possible to play multiplayer-games with 4 player (excluded FBA)? Definitely want to play games like Nintendo World Cup (NES) or various Bomberman (SNES) with 3 friends. Thanks!
        Hello for snes look this :http://blog.recalbox.com/forums/topic/multijoueur-sur-snes-solution/
          Hi, I let you look this post. There is a tuto about how to play 4 player on snes. But it is in french. If you don't understand using tools like google translate. Tell us, and someone will translate it.
            haha @Acris
            • joinski
              joinski last edited by
              For SNES it is possible to play with 3 or 4 players (Super Bomberman for example). To enable multitap in snes9x emulator (standard emulator for snes in recalbox is pocketsnes i think, and so you first have to switch the emulator. See here, how that works -> link) you have to do the following steps:   1) edit  retroarch.cfg (/etc), the line # input_libretro_device_p2?  « 227 », so that the line looks like this: input_libretro_device_p2 = « 257 » (delete hashtag # at the beginning of the line!) 2) Start any SNES Game and press Hotkey + B (on PS3-Controller it is X) to get into retroarch-Menu and then go to/change the following settings: Setting > General Setting > Configuration Save On Exit : ON Setting > Input Setting > User 2 Device Type > Multitap 3) Quit RetroArch
              • joinski
                lol Acris and rockaddicted were faster than me ^^ but i translated it in english and here is a german translation of it (it is also from me ^^): http://powerpi.de/tipps-und-tricks-fuer-recalboxos-die-retro-gaming-plattform-fuer-den-raspberry-pi-2/ (the third comment, when you scroll down to the comment-section)
                • 5t4m
                  5t4m last edited by
                  Wow!! I really have to thank you guys! I hoped for a reply on the next day, but you were even faster 🙂 Your posted information should help me a lot. Looking forward to play SNES in 4 player mode. @joinski: Über deinen Guide bin ich überhaupt auf das recalbox OS gekommen. Werde das die Tage mal bei meinem alten Raspberry Pi B probieren und dann das B2 holen. Danke!
                  • joinski
                    Der Guide (also die Seite powerpi.de) ist nicht von mir ^^ Ich helfe dem Aki (Initiator der Seite) nur ein wenig beim Beantworten der Fragen 😉
                    • 5t4m
                      5t4m last edited by
                      Hi all, Just to be sure, for SNES 4-Players are supported (via Snes9x and instruction above), but FCEUNext (NES) is only working for 2 Player ?
                      • 5t4m
                        5t4m last edited by
                        Hi all, My Recalbox is now working (with 4 player support for snes) just fine in about 2 hours work. Thanks a lot! However I am not able to get 4 players for nes working. Tried Nestopia and fceunext, but neither worked for me. Was someone from you guys able to make that work? I came across 2 topics for nestopia and 4 player support and am still working on it: http://libretro.com/forums/showthread.php?t=3164 https://github.com/rdanbrook/nestopia/issues/146 Any information would be appreciated!
