    playstation roms don't open
    Emulator Arcade/PC/Console
    playstation roms dont open
    9210
    • halflifebe
      halflifebe last edited by
      Hi everyone,
      I'm prety new here.
      I've tested a lot of rom's on a lot of different consoles (nes, supernes, gamegear,...) I works great!
      But I can't use any rom for the playstation 1 neather the dreamcast.
      For exemple, I have a game for playstation with 2 files (.bin and .cue)
      If I put those files on my recalbox, the name of the game appears on the emulator interface, but the game does not open 😞
      Same problem with the dreamcast (with .bin and .gdi files)
      Can anyone help?
      Thanks,
        OyyoDams Staff @halflifebe last edited by
        @halflifebe Hi,
        You need bios for these emulators. Please read the documentation 😉
        • halflifebe
          Thanks @OyyoDams, I have the bios.
          It appears that it only works if I upload the roms directly from the osx finder (and not from the web interface.
          • userreddit
            userreddit last edited by
            When I try to upload PSX ROMs, it says that the file is "too large".
              OyyoDams Staff @userreddit last edited by
              @userreddit don't use web manager for huge roms, transfert them via winscp or network share directly.
              userreddit 1 Reply Last reply Reply Quote 1
              • userreddit
                userreddit @OyyoDams last edited by
                @oyyodams D**n, it's sure going slow. Like, it says it's going to take 48 minutes to transfer a file that's 600MB.
                  @userreddit how do you transfert it ? how is your network ?
                  userreddit 5 Replies Last reply Reply Quote 1
                  • userreddit
                    @oyyodams I'm using WinSCP over my WIFI network.
                    • userreddit
                      @oyyodams Currently, my speed is 10mbps.
                      • userreddit
                        @oyyodams So, now my Playstation game is uploaded. However, it won't play.
                        • userreddit
                          @oyyodams Nevermind, I'm dumb. I forgot about the BIOS.
                          • userreddit
                            @oyyodams Sorry about posting so many times. It won't let me edit my posts. So, I installed the BIOS and it's still not working. I used SCPH1001.
                              paradadf Staff @userreddit last edited by
                              @userreddit assuming your bios file is correct, be sure the format of your cds is also correct and you have the cue files to launch the games (if applicable) and that your games aren’t protected (mostly for EU games), in which case you should find the .sbi files and place them nect to the roms.
                              userreddit 1 Reply Last reply Reply Quote 0
                              • userreddit
                                userreddit @paradadf last edited by
                                @paradadf It ended up that I had uploaded the .rar of my rom instead of the .bin. Once I extracted the .bin, it worked.
