    Coin Acceptor with RecalBox
    Community projects
    coin acceptor recalbox
    5203
    • IvoLourenco
      IvoLourenco last edited by
      Gents,
      I’m building a arcade table using Recalbox. My system is fully working. I was thinking on adding a coin acceptor to it for fun. But I could not found any thread on this matter. (Inlight me if already exist)
      The current setup has two players and uses a two independent buttons for insert coin on each player. What I want is to replace this buttons by a single coin acceptor?
      I know that is possible with retropie in parallel with a zero delay card. However, I want to connect it through GPIO. Probably I would need to have an independent energy source as it is 12v.
      Thanks in advance for the support.
      Ivo
      • kjbstar
        kjbstar last edited by
        Hi,
        There's a french tutorial for a single coin slot. Dunno if there's english version, but maybe with Google translate...
        https://github.com/recalbox/recalbox-os/wiki/Brancher-un-Monnayeur-Comparatif-sur-un-Raspberry-Pi-(toutes-versions)-(FR)
        • IvoLourenco
          @kjbstar Thanks for the input. I´m afraid there is no way to use a single coin acceptor to replace both buttons. If there is any other information that someone can have will be welcome.
          • IvoLourenco
            Hello @tong-man, i noticed that the link mentioned above was developed by you and reference on your youtube channel. I noticed that your bartop as two players. So my question is: When you insert a coin your credits are assumed as 'general credits' and both players can take them?
            tong-man 1 Reply Last reply Reply Quote 0
            • Dragu
              @IvoLourenco
              I put coin acceptor, but I used encoders, it should be the same with gpio buttons. Just necessary to separate 12V from 5V. you find the schematic that I use on my bartop here :
              https://forum.recalbox.com/topic/11344/1-bouton-select-branché-sur-2-encodeurs-usb
              I switch both select1+2 with one 12Volt button on relay, and I can also choose between freeplay or coin, with illuminated select(s) button in case of activity.
              I put also modification to exit the coins behind instead under, more place.
              https://www.youtube.com/watch?v=LP8KPmCjZSE&list=UU53uZov-zVaGZ82Ymv4TXcw&index=5
              • IvoLourenco
                @Dragu I did not fully understood your schematic, i already bought the relay and now I'm planning on getting the PCB to create the interface. I believe i understood the philosophy behind. Basically you insert one token and it flags on both encoders. But in that scenario 1 coin gives always two credits. So if this thinking is correct you would be fine to use @tong-man solution with a split wire at the end, so I can connect to both GPIO pins, no?
                • Dragu
                  @IvoLourenco
                  As example Neogeo. If you push/insert, he consider 2 players and add everytime 2 coins. For be able to play as 2 you would otherwise need to insert 1 coin/push, but on every Select separate. Its up to you to choose.
                  • tong-man
                    tong-man @IvoLourenco last edited by
                    @ivolourenco said in Coin Acceptor with RecalBox:
                    Hello @IvoLourenco , into "dips switch options" of the neogeo, mame and fba systems, u can affect the "insert coin" button for the 2 players. U can also affect x coin for x credit for each players etc...
                    Tips RecalBox > https://lc.cx/xAcs
