[SOFT] Arrm (Another Recalbox Roms Manager)
Hi everyone,
A new version of ARRM is available:
2.0.1.2 (24/12/2023)
- Modification: When searching on launchbox, removed the : in the game title, replace with -
- Fixed: Even if 'Keep one genre' was not checked in the 'Gamelist' tab, only one genre was saved in gamelist.xml (not in gamelist_arrm.xml which kept all genres)
- Modification: From now on when scraping on Arcade Italia, the game titles returned will be the long titles (eg: Top Driving (version 1.1.)) instead of the short titles (Top Driving). Use 'Clean Name' to remove this extra information.
- Modification: Retroarch export is compatible with the different Retroarch platforms (Windows, Android, Linux, Wii etc....)
- Modification: In the Retroarch export module, addition of the choice of 'Retroarch Cores folder' so that the correct core is indicated in the playlists (.lpl). Wiki : https://shorturl.at/dlrJN
- Fixed: When scraping with Missing Media checked, MIX enabled and no media checked, the MIX is now correctly generated.
- Added: For renaming Arcade Rom titles via DAT files, it is possible to indicate which DAT file to base on. See wiki: https://shorturl.at/jDEKT
- Added: It is possible to check the integrity of media (corrupt, unreadable, etc.) when loading a gamelist if the 'check if media exists' checkbox is checked, or via the 'Media exists?' button. from the 'Selected Roms' tab. If a media is corrupted, it is deleted as well as its reference in the database. See wiki : https://t.ly/4gOmm
- Added: It is possible to export a gamelist in %nom_platform%_GAME.csv format which you can use to constitute your GAME.CSV present in distributions such as 'GameStick Lite' See wiki: https://shorturl.at/CDHT9
- Fixed: Various bugs
Download link: https://shorturl.at/bintv
Donwload link for ARRM without installer : https://shorturl.at/osEN2
Download link for Beta: https://shorturl.at/orsW0Changelog : https://shorturl.at/chS18
ARRM WIKI : https://shorturl.at/aiBLT
Videos tutorial playlist : https://shorturl.at/gizDN
Donations : https://shorturl.at/iAFJK -
Hi everyone,
2.0.1.5 (16 January 2024)
Changelog:
- Correction: If the 'stop' button had been previously used, the process linked to the 'Bezel project' button stopped immediately without processing.
- Modification: The local image search (checkbox: Find missing images) as well as the Renaming of Artworks ('Rename Artworks' button) now case sensitive.
- Addition : add 'assets.bezel' in Pegasus export. Wiki : https://shorturl.at/dfyMQ
Modification: URL modification of the Screenscraper API in order to relieve Screenscraper servers. - Addition: system for copying configuration files if not present when launching the application. This avoids overwriting your file settings.
- Correction: When translating a description, if the translation contained a & the text was truncated
- Correction: The checkbox '→1280×1024' in the 'Images Options' tab used to resize overlays produced incorrect coordinates for Batocera.
- Modification: On GameTDB the search via the Nintendo or PS3 game ID can be done if this ID is present in the file name between []. For PS3 it is not necessary for the ID to be between []
- Correction: retrieval of Thumbnail and Marquee tag images could be faulty.
- Modification: When retrieving Wheel / Wheel-hd from Screenscraper, ARRM will take one or the other depending on their availability
- Modification: During image recovery on Screenscraper, several retries are performed on images whose download has failed
Changelog: https://t.co/8bG1fCDa3o
Download link: https://t.ly/FHgdd
Donwload link for ARRM without installer : https://shorturl.at/dHLTV
Download link for Beta: https://t.co/BA35b7vK6SARRM WIKI: https://shorturl.at/hsy38
Videos tutorial playlist: https://shorturl.at/cuA49Discord: https://discord.gg/p7QsBTS
Twitter: https://twitter.com/ARRM_sofware
Facebook: https://www.facebook.com/ARRMbyNexusone13Donations: https://shorturl.at/hCGN5
Hi everyone,
2.0.1.6 (17 february 2024)
Changelog:
- Fixed: When scraping SteamDB, an invalid game date could cause an ARRM crash
- Fixed: The 'export' button produced an error when it was clicked when no system was loaded into the database
- Fixed: During a Launchbox scrape the Extra1 image was not recovered when the 'Missing Media' checkbox was checked
- Fixed: When using the 'Rename Artworks' button, the application could crash if the 'Image' tag was not entered
- Added: Scrape engine configuration files and extensions file updated are stored in the 'database\original_config_files' folder.
- Added: 'Update system names' button in the 'Tools' tab which allows you to update your different scrape engines configuration files and extensions file with the systems that you have not declared without overwriting your own configurations. Wiki : https://rb.gy/nsgxgy
- Added: 'Shutdown' button in the 'Tools' tab which allows you to turn off your Frontend.
- Added: CheckBox 'Keep one region' in the 'Gamelist' tab: If checked, when saving the gamelist.xml, in the case of multiple regions, only the first region of a game is kept (respecting the order of priorities of the texts). If no match is found and there are multiple regions, the 'WOR' region will be selected. Useful for some themes that display a flag based on region
- Added: CheckBox 'Keep one language' in the 'Gamelist' tab: If checked, when saving the gamelist.xml, in the case of multiple languages, only the first language of a game is kept (respecting the order of priorities of the texts). If no match is found and there are multiple languages, the 'EN' language will be selected. Useful for some themes that display a flag based on language
- Modification: Taking into account disk references in square brackets when creating M3Us
- Modification: Taking cookies into account when calling the Screenscraper API
- Modification: Addition of various system names in the different scrape engine configuration files and the systems_extension.txt file
- Modification: The suffix for the media bezel can now be blank as well (formerly forced to -bezel when empty)
This post is deleted!
