    Odroid XU4 is way, way better at emulation than the Rpi 3.
    Your discoveries
    odroid xu4 better
    9
    17
    10324
    • MegaTimX
      MegaTimX last edited by
      I got two Rpi 3s to gift to family members, and while testing PSP games I was shocked at how poorly the Rpi 3 handles the system. I looked online and see people overclocking their RPi3s, buying heatsinks and fans to try and run PSP.
      Why not just invest in an Odroid XU4 or XU4Q? At a cost of around $65(30 more than an RPi3) No need to even overclock and you'll be crushing PSP and N64, even playing some dreamcast.
      I really appreciate the fact that RecalBox is developing for the XU4, and I'm looking forward to future releases.
        Substring @MegaTimX last edited by
        @megatimx yeah, the xu4 is more powerful than anything else. It will get an important update next year
          voljega Banned @Substring last edited by
          @substring software update or hardware update ?
          Substring 1 Reply Last reply Reply Quote 1
            Substring @voljega last edited by
            @voljega software : new kernel, probably an updated gpu driver. Much work to do before even thinking about it
            • MegaTimX
              Looking forward to the update. The only better option would be to put an itx or mini-stx(preferably) PC into a console. I was considering it, but it would cost a few hundred dollars to get a decent system. The XU4 has a good price to power ratio.
                @megatimx once x86 kernel and gpu drivers are updated, i'll give a go to some atom Z8350 mini PC
                snwfrd38 1 Reply Last reply Reply Quote 0
                • fatice
                  fatice last edited by
                  I have RP3 and U3. It would be nice if I can use my U3 to run Recalbox.
                  According to Odroid forum, XU4 and U3 are software compatible, but not boot image compatible. It needs to change the kernel and mali library. Is there any one has a Recalbox image for U3?
                  Is there any step by step instruction on building XU4 image from source so that I can try it on U3?
                  hex12 Substring 2 Replies Last reply Reply Quote 0
                  • hex12
                    hex12 @fatice last edited by
                    @MegaTimX the only thing is taking me from using is that RecalBox does not have Amiga emulation for Odroid, that is a best for me. If Amiga will be enabled also for Odroid, i think that it will take the place of Pi3, almost till Pi4 will not show more power. But as i don't think Amiga will be port for this system for now, i will remain with Pi3 and a native N64 on my desktop...
                      Substring @fatice last edited by
                      @fatice no support for U3. It will never happen, too few people concerned with it and i think the board is discontinued
                      fatice 1 Reply Last reply Reply Quote 0
                      • fatice
                        fatice @Substring last edited by
                        @substring I don't expect it will be released here. I was hoping to get a direction or customization steps on the build system. Currently, github download has preset profile for different system. It does not have U3 or at least it is not easily modified from XU4 to U3.
                          @fatice we moved to gitlab a year ago. You'd need to write a defconfig file for U3 at least
                          • snwfrd38
                            snwfrd38 @Substring last edited by
                            @substring
                            It aeems (see on youtube) that the new rizen 3 2200g is doing a very good job for dreamcast, psp and even some wii u. Looks like a path forward for mini PC boards!
                            Pi0w plus GPI avec 32G
                            Pi3+ plus Nescase avec 128G
                            Hors RB
                            Bartop PC sur Launchbox avec 4Tb HDD
                            BlockABoots 1 Reply Last reply Reply Quote 1
                            • BlockABoots
                              BlockABoots @snwfrd38 last edited by
                              @snwfrd38 You'd still be looking at around £300 for a system though (APU, Memory, Harddrive, Mobo, PSU and Case) and then an OS...unless Recalbox do a OS image for x86/64?
                              So compare that to £70 for a XU4 its no contest really yes games will run better on the Ryzen but you have to pay for that....maybe a older cheaper Intel NUC unit would be the best of both worlds?
                                paradadf Staff @BlockABoots last edited by
                                @blockaboots fyi there is an x86 version of recalbox.
                                aceplayer01 1 Reply Last reply Reply Quote 0
                                • aceplayer01
                                  aceplayer01 @paradadf last edited by
                                  @paradadf I’m trying to find help installing recalbox x64 on a secondary disk on my ryzen1600/rx580 system. The OS gets to the installer screen then it’s just black from there, waited about an hour. Is there a forum thread or somewhere I can go for support?
                                    voljega Banned @aceplayer01 last edited by
                                    @aceplayer01 why do you post on a odroid xu4 thread which has nothing to do with your problem ? open your own thread
                                    • aceplayer01
                                      aceplayer01 @voljega last edited by
                                      @voljega I've searched these forums high and low for support on RecalBoxOS x64 on AMD hardware and this is one of two post that even mentions Ryzen.
