    Latest upgrade after 4.1
    latest upgrade 4.1
    8311
      OyyoDams Staff @bernardoortega last edited by
      @bernardoortega said in Latest upgrade after 4.1:
      Unknown SSL protocol error in connection to recaleur-archive-prod.recalbox.com:9443
      Check again your network configuration, something is blocking connection!
        Substring @bernardoortega last edited by
        /recalbox/scripts/upgrade//recalbox-canupgrade.sh --from-version 4.1.0-master-rpi3-2017-10-12-19-13-15-36064905 --service-url https://recaleur-archive-prod.recalbox.com:9443 --arch rpi3 --uuid a0a7745d-be61-45d5-a399-823e9281adcd
        Can you give the output of bash -x /recalbox/scripts/upgrade//recalbox-canupgrade.sh --from-version 4.1.0-master-rpi3-2017-10-12-19-13-15-36064905 --service-url https://recaleur-archive-prod.recalbox.com:9443 --arch rpi3 --uuid "a0a7745d-be61-45d5-a399-823e9281adcd" ? Please enclose the result between 3 back quotes like :
        blablabla
        It should make a:
        blablabla
        bernardoortega 1 Reply Last reply Reply Quote 1
        • bernardoortega
          bernardoortega @Substring last edited by
          @substring said in Latest upgrade after 4.1:
          @Substring Here is the output:
          Note that i am not connected to any country VPN here:
          + [[ 8 -gt 1 ]]
          + key=--from-version
          + case $key in
          + FROM_VERSION=4.1.0-master-rpi3-2017-10-12-19-13-15-36064905
          + shift
          + shift
          + [[ 6 -gt 1 ]]
          + key=--service-url
          + case $key in
          + UPGRADE_URL=https://recaleur-archive-prod.recalbox.com:9443
          + shift
          + shift
          + [[ 4 -gt 1 ]]
          + key=--arch
          + case $key in
          + ARCH=rpi3
          + shift
          + shift
          + [[ 2 -gt 1 ]]
          + key=--uuid
          + case $key in
          + UUID=a0a7745d-be61-45d5-a399-823e9281adcd
          + shift
          + shift
          + [[ 0 -gt 1 ]]
          + [[ -z 4.1.0-master-rpi3-2017-10-12-19-13-15-36064905 ]]
          + [[ -z https://recaleur-archive-prod.recalbox.com:9443 ]]
          + [[ -z rpi3 ]]
          + [[ -z a0a7745d-be61-45d5-a399-823e9281adcd ]]
          ++ curl -f 'https://recaleur-archive-prod.recalbox.com:9443/v1/upgrade?arch=rpi3&boardversion=4.1.0-master-rpi3-2017-10-12-19-13-15-36064905&uuid=a0a7745d-be61-45d5-a399-823e9281adcd'
            % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                           Dload  Upload   Total   Spent    Left  Speed
            0     0    0     0    0     0      0      0 --:--:-- --:--:-- --:--:--     0
          curl: (35) Unknown SSL protocol error in connection to recaleur-archive-prod.recalbox.com:9443
          + VERSION_URL=
          + [[ 35 != \0 ]]
          + echo 'no upgrade available'
          + exit 2
          Now, i connected to France as example the VPN and this is the results:
          + [[ 8 -gt 1 ]]
          + case $key in
          + shift
          + shift
          + [[ 6 -gt 1 ]]
          + key=--service-url
          + case $key in
          + shift
          + shift
          + [[ 4 -gt 1 ]]
          + key=--arch
          + case $key in
          + ARCH=rpi3
          + shift
          + shift
          + [[ 2 -gt 1 ]]
          + key=--uuid
          + case $key in
          + shift
          + shift
          + [[ 0 -gt 1 ]]
          + [[ -z rpi3 ]]
          100    36  100    36    0     0    126      0 --:--:-- --:--:-- --:--:--   146
          + VERSION_URL=https://lb-archive-prod.recalbox.com
          + [[ 0 != \0 ]]
          ++ curl -f 'https://lb-archive-prod.recalbox.com/v1/upgrade/rpi3/recalbox.version?arch=rpi3&boardversion=4.1.0-master-rpi3-2017-10-12-19-13-15-36064905&uuid=a0a7745d-be61-45d5-a399-823e9281adcd&source=recalbox'
          100     9  100     9    0     0     24      0 --:--:-- --:--:-- --:--:--    27
          + AVAILABLE_VERSION=17.12.02
          + [[ 17.12.02 != \4\.\1\.\0\-\m\a\s\t\e\r\-\r\p\i\3\-\2\0\1\7\-\1\0\-\1\2\-\1\9\-\1\3\-\1\5\-\3\6\0\6\4\9\0\5 ]]
          + echo https://lb-archive-prod.recalbox.com
          + exit 0
          Now i can see the update on the GUI and now is been downloaded, so we can confirm a network issue that perhaps some ISPs block the port and not others. E.g same VPN connected to Spain did not work, but the one to France it is.
          Thanks for your help to all
