    custom.sh problems (again!)
    custom.sh again
    2769
    • stigzler
      stigzler last edited by
      Hi folks,
      Since new update, this function appears to be broken again... 😞
      I have recalbox pointing to a a usb3 drive as the main drive. On it, under shares/system, I have the script "custom.sh":
      #!/bin/bash
      echo "Starting Cutom.sh"
      recallog "Starting FANCONTROL"
      python fanControl.py
      fanControl.py runs a fan script.
      if I explore the log, it shows that it IS automatically running the script:
      [       21.95] Starting S94manager
      [       22.14] ... Starting manager v2
      [       22.39] Starting pm2
      [      844.02] Starting FANCONTROL
      [      939.45] Starting FANCONTROL
      [      969.53] Stopping Emulationstation
      However, the fan doesn't run.
      If I putty in and run via:
      ./custom.sh
      it does run!
      So - what's going on here!?
      • stigzler
        UPDATE:
        updated my script to:
        #!/bin/bash
        recallog "Current Directory: "
        recallog $PWD
        /usr/bin/python /recalbox/share/system/fanControl.py
        Still no joy. 😞
        Weird log, though:
        [ 22.45] ... Starting manager v2
        [ 22.66] Starting pm2
        [ 106.81] Starting FANCONTROL
        [ 106.83] Current Directory:
        [ 106.85] /recalbox/share/system
        [ 157.25] Starting FANCONTROL
        [ 157.28] Current Directory:
        [ 157.37] /recalbox/share/system
        [ 179.70] Starting FANCONTROL
        [ 179.72] Current Directory:
        [ 179.74] /
        [ 6.91] No need to upgrade configuration files
        • stigzler
          @Substring - hey fella - you helped with this last time - any ideas?
          Sorry to b*mp my own post, but desperately trying to get this recalbox setup so I can post it this weekend to a friend who lives in France for xmas!
          • stigzler
            stigzler last edited by stigzler
            nemmind. Sussed it:
            	#!/bin/bash
            	recallog "Custom.sh called"
            	case "$1" in
            	   start)
            			 recallog "Start detected. Starting fan script"
            	   stop)
            			 recallog "Stop detected."
            	   restart|reload)
            			 recallog "Restart|Reload detected"
            			recallog "Other state detected..."
            	esac
            	exit $?
              Substring @stigzler last edited by
              @stigzler if the recallog works fine but bot the python script, i'd have a look at the script
              On the other hand if your customs.sh works on commandline, looks line an environment problem.
              Anyway, you should a annampersand & at the end oh hour python command line, no need to hold init because of your script
              • stigzler
                thanks @Substring , but the most recent code appears to work fine. NOt sure what you mean about the ampersand, but hopefully won't need it as so far so good!
                  @stigzler I mean /usr/bin/python /recalbox/share/system/fanControl.py & so that the process goes to background in multiprocessing. Otherwise you just lock the init script and never give the hand back.
                  What is your python script ? you should, for debug, run your script in custom.sh like /usr/bin/python /recalbox/share/system/fanControl.py 2>&1 | recallog & and see what the recalbox.log mentions
