    V3.3.0 beta testers needed – besoin de beta testeurs
    v3.3.0 beta testers needed testeurs
    78
    401
    342203
      Hello everyone, we have the pleasure to announce the release of recalboxOS-v3.3.0-beta ! Here is the list of new features :
      -New Systems
      -SuperGrafx
      -The PC Engine emulator now support SuperGrafx games
      -Atari 7800
      -Wonderswan / Color
      _   WSWAN black and white and color support_
      -NeoGeo
      The NeoGeo system has been added in order to differenciate NeoGeo games from other arcade ones. You can configure the NeoGeo emulator in recalbox.conf
      -NeoGeo Pocket / Color
      Handheld Neogeo support -Vectrex _   Watch your eyes !_
      -Game And Watch
      _   They woke me up every morning !_
      -Lynx
      _   The Atari handheld_
      -PRBOOM
      _   Play the legendary doom !_
      -Libretro Lutro
      Libretro team game creation framework
      -NXengine (cavestory)
      -Gameboy tgb dual
      _   Two players split screen gameboy emulator_
      -Features
      -Favorites
      _   You can select your favorites games with Y in the frontend_
      -Add of shaders
      _   Use your shaders in games. Scanlines here we are._
      -Cheats
      INFINITE LIIIIIFE
      -8bitdo and bluetooth controllers support
      _    Update your 8bitdo firmware_
      -Virtual gamepads
      _    Miroof's Virtual Gamepad https://github.com/miroof/node-virtual-gamepads Use your mobile phone as a controller. Really usefull when your pals are at home._
      -Emulationstation new configuration options
      _    Configure your network name, game rewind, ip, background sounds etc… Directly from the frontend._
      -recalbox.conf enhanced
      _    You can fine tune your emulators in recalbox.conf : see https://github.com/digitalLumberjack/recalbox-os/wiki/recalbox.conf-%28EN%29_
      -PS3 driver choice
      -bug fix / patches
      -retrobit controllers support
      -4NES4SNES controllers support
      -2 players Xin-Mo controllers support
      -Xbox patched drivers
      -1 GPIO button added per player
      You can download it on github and test it on your RPI 1 and RPI 2. https://github.com/digitalLumberjack/recalbox-os/releases The manual and the wiki, in english version, have been updated. https://github.com/digitalLumberjack/recalbox-os/wiki So now it is your time to work ! We need feedback on github issues that have been fixed with this version. Check the « need feedback » tag on github. https://github.com/digitalLumberjack/recalbox-os/issues?utf8=✓&q=label%3A"need+feedback"+   Lien vers l'article en version française présent sur le blog : http://blog.recalbox.com/2015/08/recalbox-v3-3-0-beta/   English version : http://blog.recalbox.com/2015/08/recalbox-v3-3-0-beta-EN/
      • pich75
        pich75 last edited by
        Bonjour à tous, Hi all, Dois je poster en français dans cette section ? Au besoin je retraduirai... premier post de ma part, j'utilise Recalbox depuis quelques temps maintenant et il répond à presque toutes mes attentes. Je n'ai pas peur de bricoler un Linux, mais vraiment pas le temps... Donc bravo et merci ! Je vais rapidement tester cette nouvelle version avec les scanlines et un émulateur vectrex 🙂 Y a t il un pré-scrapping des rom comme évoqué un temps ? Une question auparavant : j'ai lu qu'un réinstal complete était requise. Donc je vais perdre mes roms... que j'ai passé pas mal de temps à synchoniser (victime du bug des Pi2 à l'extinction). Existe t il une solution simple de ne pas tout perdre ? De faire une sauvegarde ? Merci beaucoup et à bientôt. Pierre
        • nejizzz
          nejizzz last edited by
          Salut a tous   je suis impressionné par la quantité de changements apportés sur la version 3.3.0 je suis vraiment content pour cet exploit surtout pour le support xin-mo usb jattendais cela depuis 2 ans maintenant et le changement de  shaders (filtres) ce qui permet davoir un effet cathodique sans avoir un ecran crt ou d'acheter un generateur de scanline a 50€   merci pour votre travail bonne continuation et longue vie a recalbox !
          • lordtaki
            lordtaki last edited by
            Bonjour, dommage effectivement qu'on ne puisse pas passer par le menu de mise à jour (peut-être une future demande pour choisir un canal alpha/beta/stable pour cette fonction). Je me demande s'il n'est pas possible quand même de trouver une solution intermédiaire (plus de 50Go à retransférer sur un vieux port usb ça prend une plombe). @ suivre
            • digitaLumberjack
              Trois choses : - je ne fais pas passer les versions stables sur les beta pour la seule bonne raison qu'il serait clairement difficile de répondre aux gens qui mettent a jour et qui arrivent sur le forum en me disant que ca marche moins bien (ca reste une beta) - la mise a jour est tellement lourde et la différence entre les 3.2.x et les 3.3.x est si gigantesque que même a la sortie de la 3.3.0 final, je ne publierais pas les maj sur les 3.2.11 - Je vais penser à ajouter une option dans le frontend ou tu peux activer le passage aux maj en beta depuis une stable.
              • cluf20
                cluf20 last edited by
                Salut, J'ai testé avec ma manette Gasia et ça fonctionne out ou the box plus besoin de faire ma bidouille avec le sixad. Par contre je pense pour d'autres utilisateurs, ce n'est pas possible de faire cohabiter les trois types de manettes ensemble ? Sinon très bien la 3.3. Je vous ferais part de mes remarques au fur et à mesure. La première, j'ai testé Rice pour jouer à Zelda sur n64. J'ai un problème avec l'image qui n'est pas centrée sur l'écran ! Pour l'image en elle même c'est pas mal par contre le son saccade un peu. Je vais tester d'autres émulateur et je vous dirais ce qui en ressort. ++ Ps: le support du dongle TP-Link TL-WN725N est pris en compte dans la 3.3?
                  Ouep pour la N64 on ne peut pas faire vraiment mieux niveau émulation sur le rpi2. Le truc que j te recommande si ce n'est pas déjà fait, c'est d'overclocker ton rpi2 via le menu settings de ES. Après pour ton image non centré, as tu forcé l'affichage en mode vidéo 3 via recalbox.conf et recommenté le mode vidéo 4 associé au plugin n64 ? Edit: inversion des mode vidéo corrigé dans le post. rice = n64.videomode=CEA 3 HDMI et n64 = n64.videomode=CEA 4 HDMI
                  • lordtaki
                    Je comprends parfaitement les raisons qui te conduisent à ne pas pousser beta sur stable. Je le voyais plus comme une option disponible uniquement en éditant manuellement un fichier de configuration (donc non accessible par l'interface graphique) pour utilisateur expérimenté qui sait ce qu'il fait. Mon avis est que tu risques d'avoir trop de support si c'est facile pour le joueur lambda 🙂 J'ai regardé comment se passer jusqu'à présent la maj du système (/recalbox/scripts/rsync-update/rsync-update.sh) je vais quand même la tenter avec mon pc et la micro sd / usb. Après tout c'est juste une histoire de chemins différents. (D'ailleurs timing parfait la sauvegarde complète de la micro sd vient de se terminer).
                    • cluf20
                      Ah ok j'avais décommenté les deux lignes du bas mais du coup j'ai pas du faire tout ce qu'il fallait !!! Je vais regarder ça ce soir ! Merci!! Sinon j'ai essayé l'overclock via le menu et ça aide bien !
                      • cluf20
                        J'ai aussi l'impression qu'il met plus de temps à démarrer! C'est une impression ou vous avez aussi ça ?
                          @Pierre le pré-scrapping est présent sur github à l'adresse suivante : https://github.com/digitalLumberjack/recalbox-gamelists il a été mis en standby ces dernier temps pour se focaliser sur la 3.3.0 mais il reprendra quand on aura le temps. (d'ailleurs si quelqu'un veut continuer le taff il est le bienvenu haha) Du coup, il n'est pas intégré de base. @Cluf20 yep il faut jongler entre les mods vidéos suivant le plugin. rice n'acceptant pas de booter en 720p... Si tu le lance en mode video 4 (720p) tu aura un affichage en 480p fenêtré dans du 720p (d'où le décallage d'image). Après si malgrès ça tu as tjrs un soucis, vérifie que ta télé a bien switché en affichage vga - 480p, et redis nous.
                          • raulval82
                            raulval82 last edited by
                            Hi all! Im trying to help with the beta tests, but Im stucked at the beggining: With a fresh install, if I try to change the fstab file to add my hdd, the games appear, but music stops and the controllers stop working too.
                            • digitaLumberjack
                              @Cluf20
                              Par contre je pense pour d’autres utilisateurs, ce n’est pas possible de faire cohabiter les trois types de manettes ensemble ?
                              Tu imagine bien que ce n'est pas possible en l’état, sinon je l'aurais fait... J'avais essayé de modifier un peu le code source de sixad, mais deja si l'auteur a mis une macro pour différencier les manettes a la compile et pas au runtime, c'est qu'on est mal barré.
                              • lordtaki
                                Mon retour sur la béta: Installation RAS J'ai du me résoudre à une réinstallation complète. Je ne suis pas assez familier avec les spécificités du raspberry pour me lancer dans un debug sur ma tentative de mise à jour manuelle. Démarrage Je rappelle que ma recalbox est blindée (plus de 20000 titres). Sur la béta c'est plus rapide (mais évidemment pas instantané comme quand il n'y a rien). Configuration Très appréciable les nouveautés. Je pense surtout à la partie réseau. Celle-ci évitera à ceux qui n'y connaissent rien de perdre du temps à chercher l'adresse ip. Les manettes PS3 gasia fonctionnent nativement comme annoncé. Les favoris sont très utiles aussi. Je dois remettre la configuration du shader puisque c'est maintenant intégré. Scrape intégré Là aussi j'ai trouvé qu'il était plus réactif. Toujours le même comportement pour emulationsation. On clique sur sauvegarder mais ce n'est écrit dans les fichiers gamelist.xml qu'à la sortie du processus. Conséquence, je n'ai pas joué avec le feu avec m'être énervé sur quelques titres. Direction F4 pour tuer emulationstation. Ecran noir, j'enchaîne sur ALT+F2 mais je ne choppe pas la console comme d'habitude. Pas grave, connection ssh, je monitore via "ps -efl | grep emul" et je vérifie la date des fichiers gamelists "ls -l /root/.emulationstation/gamelists/*/gamelist.xml". Conclusion. Il faut attendre 10 minutes entre l'interruption demandée (F4) et l'écriture de toutes les gamelists. Systèmes Pour l'isntant c'est KO pour moi côté lynx. Mais en même temps sur ma PSP c'est KO aussi. Le hash du bios est bon. Je vais quand même en essayer un autre. Sinon c'est peut-être mon romset.
                                • cluf20
                                  Bon j'avais oublié de recommenter les lignes avec n64 mais j'ai toujours le même problème avec Rice l'image n'est pas centrée, avec tous les modes de la télé j'ai toujours une bande noir sur la droite de l'écran !
                                  • cluf20
                                    @digitalLumberjack Ok oui en effet ça doit être la m....! Après la solution est simple ! Il suffit d'avoir le même type de manettes!! 😉
                                      Guest last edited by
                                      Bonjour, félicitation pour le travail effectué. On ressent une réelle évolution dans cette future version. Voici les quelques points que j'ai remarques : - Pour l'arcade : Metal Slug 3 ne se lance pas dans la partie neogeo (mais se lance dans la partie fba libretro). Je vais en essayer d'autres mais je n'ai actuellement rencontrer aucun autres jeux que fba ne lance pas (sauf les classique red earth a cause de sa protection et moonwalker). - Pour la configuration automatique de la manette xbox 360 filière. Pour la psx les touches sont redevenue logique mais le joystique ne fonctionne plus (il permettait d'effectuer les même chose que la croix directionel). Sur emulationstation, les touches sont inversée par rapport a l'aide (exemple valider est sur B au lieu de A).  Il semblerait qu'aussi sur super nes et pc engine, il y a les touches inversés. Et comme d'hab, joystique ne fonctionne pas. Derniers points, est il possible de créer des configs de touche personnaliser pour un jeu en particulier (example jojo sur cps3 ou B arrete le jeu.)
                                        @Cluf20 te serait-il possible de vérifier que ta TV passe bien en mode vga 640*480 au boot d'un jeu n64 avec le plugin rice stp ?
                                        • rudyprome
                                          rudyprome last edited by
                                          Bonjour, j'ai installé de mon côté aussi cette version Beta donc je suis volontaire à la remontée des bugs que je peux constater. Pour ma part, je constate un problème côté sur l'émulateur Mame : les touches sont bien remontées correctement via les scripts de configuration automatique mais la touche pour ajouter un jeton ne semble pas fonctionner. Y a-t-il d'autres personnes dans la même situation ? J'ai depuis peu une erreur qui s'affiche lorsque j'allume ou éteint le raspberry. Le message apparait sur écran noir entre les images de chargements Recalbox : "ext4 fs error device mmcblk0p6 ext4_mb_generate_buddy 757 group 0 block bitmap and bg descriptor inconsistent 20727 vs 20733 free clusters" ; Le problème viendrait-il de ma carte SD qui contiendrait des blocs défectueux ?   Enfin j'ai quelques suggestions : Il est impossible de se connecter au Recalbox en SFTP via Filezilla par exemple. Je trouve qu'il serait vraiment pas mal et très pratique d'ajouter un accès SFTP dès le niveau du "/" ou le rajouter par défaut sur le partage Samba avec le besoin du compte Root pour y accéder. Une éventuelle possibilité de rajouter une vidéo au boot du Recalbox à l'aide d'OMXplayer par exemple pour accentuer la personnalisation de la console ? (tout en gardant les logos Recalbox) Un update de Kodi en version 15 stable est-il prévu ? Il n'y a absolument aucun "apt-get", "yum", "dpkg" ou autre de possible ?   Merci !
                                          • digitaLumberjack
                                            @Rudy Salut et bienvenue.
                                            Pour ma part, je constate un problème côté sur l’émulateur Mame : les touches sont bien remontées correctement via les scripts de configuration automatique mais la touche pour ajouter un jeton ne semble pas fonctionner. Y a-t-il d’autres personnes dans la même situation ?
                                            Il faut utiliser une autre touche que select pour la hotkey, le problème vient de la. Je sais que t'as une nes30 alors ça risque d’être difficile car t'as pas d'autres touches, et si tu mets R1 tu va te retrouver a faire des combinaisons sans le vouloir. Pour ton erreur, c'est un soucis sur le système de fichier, il faut juste faire un fsck sous linux (ou laisser comme ca sinon, si ça dérange pas. Par contre c'est quoi la marque de ta carte sd, j'ai peur que tu n'ai plus de problèmes encore, si ca commence avec un soucis de ce genre. Pour le transfert de fichier, tu peux utiliser winscp, pour la video, pourquoi pas mais c'est pas la priorité, pour kodi on est dessus, pour les gestionnaires de packages non c'est pas possible.
