    Issue with USB Sound card on RPi Zero W
    issue usb sound card zero
    2447
    • smarti
      smarti last edited by
      Hi all,
      I recently started a GameBoy Zero project, but I struggle with the sound...
      I use a basic USB pnp sound card, plugged on the USB port of the RPi Zero W (with the last version of recalbox).
      When the system is ON, the sound card flashes with the red led, but no sound comes from the headphone...
      I tried the same USB sound card on my laptop and it works like a charm.
      I tried to configure to alsa.conf to put the card 1 as primary.
      In alsamixer, I'm able to select the USB pnp sound card, manage the sound level.
      But after the reboot, nothing changed, I don't have any sound coming for the headphone.
      If anyone has already used this kind of USB Sound card on RPi Zero W, I take any recommendation.
      Thx
      Bye
      Seb
        Substring @smarti last edited by
        @smarti Hi
        In ES, just set the sound card as the default device, then reboot
        • smarti
          Hi @Substring
          How do you proceed ?
          I applied the proc describe here : http://www.knight-of-pi.org/raspberry-pi-enable-an-usb-sound-card-for-raspbian-jessie/
          But nothing changed.
          Thx
          Seb
            @smarti you're not using raspbian, are you ?
            As I said : start Recalbox and in EmulationStation, Press start, go to sound options, select your sound device, and reboot
            • smarti
              Thx @Substring ,
              I'm using the last official Recalbox distib. I'v downloaded the img for RPi 1/0.
              That was the first thing I've tried.
              If I select Auto, Jack or HDMI, the result is always the same : no sound in my headphone.
                @smarti your sound card should appear in the list. If not, i guess it's not recognised. What does cat /proc/asound/cardsreport ?
                • charlieman
                  charlieman last edited by
                  Hi @Substring I have same issue but mine does show on the list:
                  0 [ALSA ]: bcm2835_alsa - bcm2835 ALSA
                  bcm2835 ALSA
                  1 [Set ]: USB-Audio - C-Media USB Headphone Set
                  C-Media USB Headphone Set at usb-20980000.usb-1.2.1, full speed
                  Still switching HDMI/Jack/Auto wont output any sound.
                    Hello @charlieman
                    Please create own topic.
                    100.8k
