    Disappeared games for ps1
    disappeared ps1
    2554
    • Vern
      Vern last edited by Vern
      Hello!
      I have a problem:
      After installing the last update in my recalbox, the games for ps1 disappeared. But in recalbox\share\roms\psx they are. How can I return the lost games?
      P.S. Sorry, I use a translator.
        hello
        in recalbox 4.1 need cue file with bin file.
        Vern 1 Reply Last reply Reply Quote 0
        • Vern
          Vern @acris last edited by
          @acris, thank you!
          • farbkasten
            farbkasten last edited by
            @Vern you can use this: PSX CUE Maker to make a .cue file out of your .bin files.
            Tepoo 1 Reply Last reply Reply Quote 0
            • Tepoo
              Tepoo @farbkasten last edited by
              @farbkasten
              i am not sure if this website will work correctly.
              a cue file is not just a list of the bins, it also contains correct timestamps.
              if they are wrong, the game will end up somewhere in a blackscreen.
              best example for this is Tekken3, which endsup in a blackscreen after the arcade mode, if the CUE file is not 100% correct.
              • farbkasten
                Some games have multiple .bin files when downloaded, then it works with this website.
