    [EMULATION] Amiga4Recalbox v0.8999999999, install in one click (or so)
    Community projects
    [emulation] amiga4recalbox v0.8999999999 click
    13
    119
    45376
    • kjbstar
      kjbstar @voljega last edited by
      @voljega C'était pas que pour le s**t, mais l'ensemble de ton oeuvre. Je m'attendais à "ne lis pas mes posts", classique... 8 fois sur 10 t'engueules les gens dans tes interventions, et c'est donc aux autres de pas te lire. Ce qui est con car t'es pas con. C'te gâchis. Bref.
      • Wulfman
        Wulfman last edited by
        Settlers with your Amiga1200-Config: Works - Glitches in Intro - Worldsize 8: Perfect!
        BUT: your resolution makes it unplayable (see screenshot from yesterday). I can't change this really with your config. I don't have an idea whats wrong. If i have time i will check your config vs. my config - whats differ.
        This problem brings me to an Feature request: User-UAE-Files
        I think it is a better to use "User-UAE-Files" instead "Create-an-UAE" - what you are do (for some config-parts) with amiberryConfig.py (and the other .py)
        Your Solution: whdload
        • User start whdload-game.uae in ES
        • the whdload-game.uae has parts from your standard_forceratio_XXX.uae (the user must copy this manually)
        • amiberryConfig put some parts to your temporary-uae (/tmp/amiga/whdl/...) and overwrite (some) variables [gfx etc.]
        • this temporary-uae now start with uae4arm
          Something wrong?
        Disadvantage:
        • User must change the Gfx-Settings for an game (settler for example).
        • User want change the Quit/Menu-Button (key works, button not)
        How does the user do it? Over Menu? 😐 or directly via amiberryConfig.py ... for advanced user: no problem. You are in a bad Support-Position 😞 You can't really help because the needed settings are "hardcoded"
        Advantage:
        • easy to use ...
        My Idea for an solution: whdload
        For whdload you need an .uae - it's a must-have (user MUST create one file). You offer two default.uae-Files for this. That is ok! But if you "kill" the config-create-Part in your .py's and put this part to your default-config, you gave the users more flexiblity and YOU can easilier help ("change resolution in gameName.uae to ..."). I think this should be easy to code: "if filename has *.uae then put only drive-settings to .uae". T
        Disadvantage:
        • YOU must code this ...
        • User: no disadvantage. You say now: use "standard_forceratio_1200.uae" as template for gameName.uae. It doesn't matter if there are 3 Lines or 20 Lines. Why can't the user copy the complete config?
        Advantage:
        • YOU can give easier support
        • (advanced) User: are more flexible
        • Wulfman
          I have a solution approach for the custom1-Set-Problem (HistoryLine)
          Download HistoryLineDe (internetarchive) and start it - you will see the custom1-Error.
          Do following:
          1. Start whdload-Game
          2. go to /tmp/amiga/WHDL/S/
          3. open Startup-Sequence
          4. edit first line: Whdload HistoryLineDe.slave PRELOAD CUSTOM1=1
            (slave depend from gamename.slave - of course!)
          5. open UAE-Menu
          6. RESET
            => Game works.
          It is possible to set LOCAL-Parameter in "Startup-Sequence". Very good!
          Problem:
          You create this Startup-Sequence in whdlGenerator.py L70-79
          But how can you set "individual" LOCAL-Parameter?
          IDEA:
          1. open GameName.uae (from /roms/amigaXXX/)
          2. NEW Parameter: whdloadlocal = CUSTOM1=1 (mhh 2 "=" should not working? CUSTOM1#1? only an idea/example; you have to see what works)
          3. in whdlGenerator.py you check content of the .uae "if whdloadlocal set then read variable-value, change # to = and put it to (Line 79) fStartupSeq.write("WHDload "+slaveFile+" Preload\n")"
          At this point: I don't have any idea how to pick out variables. There's something to think about;)
          (amiberry has no problem with "unknown" variables in .uae ... i've check this with "asdfgasdfsd = 1" - no error :=) )
            voljega Banned @Wulfman last edited by voljega
            @wulfman said in [EMULATION] Amiga4Recalbox v0.8999999999, install in one click (or so):
            Please re-read the README, this is already done, why do you think there are some parts in the uae file ? Well maybe README is not clear enough.
            With an empty uae file you get the default config
            But with a custom uae like the one I provide you can overload hardware and controller parts (using ;hardware and ;controls blocks, config for that part in the uae will be used and not generated automatically by the script
            I will add the graphic part as overloadable too, it's not done yet, and you're right it can be usefull
            Meanwhile I've documented all your issues : https://github.com/Voljega/amiga4recalbox/issues
            The multi disk one I just corrected, it was a random rare bug where python didn't sort files alphabetically sometimes.
            Correction is in adfGenerator.py is you don't want to reinstall everything
              I downloaded Historyline (non DE version so I will try)
              what do you mean by LOCAL-Paremeter ? CUSTOM1=1 ?
              bad solution (the uae should be purely uae), and too complicated, simpler and easier to implement one :
              if you want to add custom parameters to the launch line in startup-sequence, juste create an .prefs file with the same name as the directory and simply put your parameters in it like CUSTOM1=1
              then you'll get :
              HistoryLine (game folfer)
              HistoryLine.uae (empty or custom conf)
              HistoryLine.prefs (with just CUSTOM1=1 in it)
              and at startup startup-sequence launch line just need to be completed with what is found in HistoryLine.prefs
              and thank you for writing more clearly 😉
                voljega Banned @voljega last edited by
                @Secamfr ah si y'avait bien un souci semi aléatoire pour ton Sensible Soccer ! normalement c'est corrigé
                  voljega Banned last edited by
                  @Wulfman
                  custom graphics conf part is added and README more clear I hope
                  you can try with the settlers, I tried with Turrican 3 but my custom graphic conf of 704282 was reduced to 704200 by the emulator, maybe the game doesn't allow it
                  if you don't want to reinstall you just need to update whdlGenerator.py, uae files used by genUAE are updated too
                    voljega Banned @voljega last edited by voljega
                    @Wulfman
                    and finally for tonight, I've added the use of custom parameters for Startup-Sequence launch, see README.md to see how it's used.
                    I have prefered .whdl extension over .prefs
                    For the next problem (https://github.com/Voljega/amiga4recalbox/issues/5) of the saves during game (but I'm not sure it sill solve the issue as when saving in Theme Park the save file appears during the game and not after quitting it) you can try to edit WHDLoad.prefs in /recalbox/share/bios/amiga/whdl/S and just remove ; before NoWriteCache see if it changes anything
                    • Secamfr
                      Secamfr last edited by
                      @voljega Ok merci je vais testé ça dès que j'ai un moment.
                        @Wulfman did you manage to test if saves in WHDL are working ok now ?
                        I tried with Wings but I don't understand how to select a newly created character to play with it, it is kind of greyed-out
                        If you update now, you should reinstall the whole thing because I removed every references to uae4arm to amiberry, so most .py script files have changed
                        • Secamfr
                          @voljega J'ai fait la mise à jour et j'ai testé les sauvegardes, ça fonctionne sur CD32 mais pas sur 600/1200 (Cannon Fodder WHDL).
                            voljega Banned @Secamfr last edited by voljega
                            @secamfr réessaye avec le modif de ce matin ?
                            Si tu veux pas t'embêter, enlève juste le ; devant NoWriteCache dans le fichier .prefs de /recalbox/share/bios/amiga/whdl/ et dis moi si ça change quelque chose
                            • Secamfr
                              @voljega Ça marche nickel avec la version de ce matin 🙂
                              Moi je désactive les leds pour 600/1200 et j'ai mis le menu sur start pour la CD32 (Start est mapper sur L)
                              Il n'y a plus qu'a attendre la nouvelle version d'amiberry.
                                @secamfr cool c'était le bug le plus chiant !!
                                Je ne sais pas encore quoi faire avec les leds si je les supprime ou pas... Le mieux serait qu'on puisse les afficher d'une pression de bouton, un peu comme l'atari st mais pour l'instant c'est pas possible...
                                • mrseguin
                                  mrseguin Theme moderator last edited by
                                  euh...étant nul sur les commandes et 0_1512889909998_Capture.PNG au risque de faire mourir de rire certaines personnes ou de les faire pleurer je ne sais pas comment faire:
                                  Give 755 rights to the script : chmod 755 installAmiga.sh
                                  j ai lance winscp
                                  j ai copié le fichier install amiga dans /recalbox/share mais ensuite j ai aucune idee de comment faire...
                                  photo de mon écran jointe
                                    voljega Banned @mrseguin last edited by voljega
                                    @mrseguin ben comme marqué explicitement dans les instructions il faut te connecter avec putty, aller dans le répertoire en tapant la commande donnée puis enter puis utiliser la seconde instruction donnée en toute lettre (les commandes apparaissent comme ça) puis enter. Il faut ensuite utiliser le script en tapant son nom
                                    mrseguin 1 Reply Last reply Reply Quote 0
                                    • TotalRecall
                                      TotalRecall last edited by
                                      @voljega Merci à toi, 5 minutes grand max pour l'installation !!!
                                      Super boulot
                                      Recalboxer novice qui ne demande qu'à apprendre (Rpi4)
                                      • mrseguin
                                        mrseguin Theme moderator @voljega last edited by
                                        @voljega Merci pour la réponse mais j ai vraiment pas l habitude d utiliser les fenêtres et taper les instructions....Avec putty quand je tapais le password rien s affiche et je pensais que c était un bug c est pour cela que j ai tenter de passer par winscp mais apparemment même si le password ne s affiche pas en le tapant et en appuyant sur enter et en suivant les consignes ca s et installé:) Tout d abord je précise que j' utilise noobs avec recalbox et raspain fraichement installé il y a deux jours.j ai les bios avec les bons md5 que j ai copié dans l endroit indiqué /recalbox/share/bios .Vu que mes roms sont sur une cle usb (que j utilise depuis le début avec recalbox) j ai aussi copiés les kickstart bien renommés dans le fichier /recalbox/bios de ma cle usb.J ai ensuite copié dans des dossiers que j avas deja cree il y a quelques temps et qui ont les meme nom (amiga600 et amiga1200) sur ma cle usb des adf appropriés pour amiga 600 et 1200 et des fichiers whd en suivant la procédure (supprimer le fichier .info et créer un nouveau fichier avec le même nom et l extension uae)Mon arborescence est la suivante /recalbox/roms/amiga600/ADF/SPORT/nom du jeu.adf.( Chose étrange j avais crée un dossier a l époque que j avais nomme IPF avec des roms au format ipf mais ce dossier n apparait pas????)
                                        Quand je lance systématiquement je reviens a l écran et aucun jeu ne se lance...Par contre j ai copier les même jeux sur la carte sd et les jeux adf dans le dossier amiga600 se lancent:) Par contre dans le dossier amiga1200 les jeux adf (avec fix aga) ne se lancent pas et bloque même recalbox et les whdload ne se lancent pas (on revient au menu)....En attendant je suis quand même content d avoir pu lancer quelques jeux qui marchent et je remercie ceux qui ont permis apres leur nombreux effort d en arriver deja la !
                                        Par con dans le dossier amigacd32 j ai mis des isos (bin cue) mais ca n apparait pas dans recalbox.
                                        mrseguin voljega 2 Replies Last reply Reply Quote 0
                                        • mrseguin
                                          mrseguin Theme moderator @mrseguin last edited by
                                          @mrseguin si ca apparait mais quand je lance un iso ca revient au menu.
                                            @mrseguin hmmm bon là ça va être dur de t'aider pour l'instant parce que t'as l'air de pas trop savoir ce que tu fait de manière générale avec ta recalbox.
                                            Donc déjà faut que tu choisisses, soit utiliser la sd soit ta clé USB c'est pas l'un ou l'autre sinon forcément tes roms vont changer.
                                            Là tu mélanges les deux je ne sais pas trop comment, surement en enlevant ou remettant ta clé au petit bonheur, donc forcément tu te retrouves avec des paths ou des bouts d'install manquant, tu n'as besoin de rien créer du tout comme répertoire pour faire marcher l'amiga, le fait que tu doives le faire montre qu'il y a un problème
                                            Donc choisi, sd ou usb, une fois choisi tu restes là dessus et tu réexécutes le script et tu réessaye les différentes possibilités et on verra après
                                            et après tu restes avec le même choix si tu veux utiliser l'amiga, sinon ce ne sera pas possible.
                                            réessaye déjà ça et on verra après.
                                            100.2k
