    Reduce dreamcast texture errors ... simple solution
    Emulator Arcade/PC/Console
    reduce dreamcast texture errors
    • Ratte
      Ratte last edited by
      Limiting the RPI GFX-memory to 128MB is reducing the problems without negative sideffects.
      gpu_mem_256=128
      gpu_mem_512=128
      gpu_mem_1024=128
      BR
      André
      •Raspberry Pi model: Pi ZeroW
      •Raspberry Pi model: Pi 3B @ 1350/500/500 MHz
      •Raspberry Pi model: Pi 3B+ @ 1550/500/500 MHz
      paradadf 1 Reply Last reply Reply Quote 2
      • NeeeeB
        NeeeeB last edited by
        Except if you use an heavy theme, and it gets all fuc*** up because there is no more enough Vram to load it...
        Vieux geek ^^
          paradadf Staff @Ratte last edited by
          @ratte dreamcast isn’t available on anything lower than rpi3, so these are pointless:
          gpu_mem_256=128
          gpu_mem_512=128
          Regarding
          gpu_mem_1024=128
          And the pi3... as mention before, the WSOD can (still) be a problem, but also some arcade games woul not even start with that setting or would not have sound either.
          101.4k
