    Sven X-pad not recognise in recalbox
    GamePad/GPIO/USB encoder
    sven x-pad recognise recalbox
    3528
    • Goosya
      Goosya last edited by
      Hi. I have a problem.
      I buy "Sven X-pad" gamepad and the device is not detected in Recalbox last version 17.11.10.2 (in previous version too) on my Raspberry pi 3.
      I install RetroPie 4.3 and gamepad is detect successfully, and normally work. (RetroPie write text "PC Gamepad" is detected)
      From the Internet I learned that the "Sven X-pad" support DirectInput only. Maybe problem in this?
      How can i solve this problem. Thanks.
        Hello @Goosya
        need archive support : http://recalbox/help, plug only gamepad sven xpad
        Goosya 1 Reply Last reply Reply Quote 0
        • Goosya
          Goosya @acris last edited by
          @acris said in Sven X-pad not recognise in recalbox:
          I already plug only gamepad sven xpad and it still not work
          What does it mean? "need archive support" http://recalbox/help -Page Not Found. I dont no why.
            @Goosya
            https://github.com/recalbox/recalbox-os/wiki/Recalbox-support-(EN)
            • Goosya
              Goosya @acris last edited by Goosya
              @acris
              I do this.
              http://www110.zippyshare.com/v/XgMv4YMX/file.html
              But- no joystick found.
              Only
              iProduct- PC Game Controller in "lsusb.txt"
                Do you testing other gamepad mode ?
                http://www.sven.fi/upload/iblock_ext/support/controllers/x-pad_manual_en.pdf
                number 9 MODE indicator in manuel.
                • Goosya
                  n
                  In Digital Mode (green) now.
                  Nothing happens if i change it (not detecteding)
                  (In RetroPie work in all modes)
                    @substring or @rochaddicted idea ?
                    • Goosya
                      Maybe from Retropie drop log's files ?
                        maybe it needs a 4.9 kernel ?
                        • Goosya
                          How i can do this? Or i need a waiting update recalbox?
                          • Goosya
                            Goosya last edited by Goosya
                            Help please.
                            In Batocera gamepad work too
                            • Серж Шаманов
                              Серж Шаманов last edited by Серж Шаманов
                              hi!
                              have the same problem with a gamepad sven x-pad.
                              firmware 17.12.02
                              recalbox-support.sh
                              • Goosya
                                Goosya @Серж Шаманов last edited by
                                After update it still not work.
