    GPIO ONOFF Powerswitch / Resetbutton Problem
    GamePad/GPIO/USB encoder
    gpio onoff powerswitch resetbutton
    12264
    • supernature2k
      supernature2k @megakoni last edited by
      @megakoni
      it works without network as we use the localhost loop (127.0.0.1)
      megakoni 2 Replies Last reply Reply Quote 0
      • megakoni
        megakoni @supernature2k last edited by
        @supernature2k
        couldn't get the script to work on startup. It just didn't do anything for me. I used this tutorial step by step https://github.com/recalbox/recalbox-os/wiki/Add-your-own-startup-script-(EN)
        • megakoni
          @supernature2k so i got the new update, but nothing changed. Or is it coming in the next update?
          I didn't change the recalbox config, is there a new default one?
          supernature2k 1 Reply Last reply Reply Quote 0
          • supernature2k
            @megakoni what is your issue?
            megakoni 1 Reply Last reply Reply Quote 0
            • megakoni
              @supernature2k i still get the power button triggered with pluging something into usb or audio jack and it shuts down. This only happens when the system.power.switch=PIN356ONOFFRESET script is enabled. So i was wondering if there is a new script for power and reset function since the new update
              • supernature2k
                @megakoni no sorry, the fix is ready and should be in the next release.
                Meanwhile, you can try the script posted above.
                • megakoni
                  megakoni @supernature2k last edited by megakoni
                  @supernature2k ok thanks i'll wait then. I tried to implement (i'm a noob xD) the script but it didn't seem to run, so i don't know yet if it works
                  • megakoni
                    @supernature2k so i got the new update.
                    Can you explain me how exactly the new power switch works? Reset button is i guess like 3 seconds of pressing down to reboot.
                    But i don't know exactly how the power switch works to turn off.
                    Turning on is simple, just switch it to on.
                    But turning off it seems i have to switch 3 times, but sometimes it does not work.
                    Is there a specific period of time i have to wait for the 3 times switching?
                    unik314r 1 Reply Last reply Reply Quote 0
                    • unik314r
                      unik314r last edited by
                      Also interrested here: looks like my power and reset buttons doesn't work anymore since the last update (X-MAS update)
                      Any hints?
                      • unik314r
                        unik314r @megakoni last edited by unik314r
                        @megakoni said in GPIO ONOFF Powerswitch / Resetbutton Problem:
                        Well I managed to find out by myself: POWER button works the exact same way as RESET button: when Recalbox ON, push the power button during 3 seconds, release it --> shutdown launched.
                        So according to me, you don't have to push the button 3 times.
                        EDIT: to show they work the same way: they have the same code line:
                        # grep GPIO.add_event_detect /recalbox/scripts/rpi-pin356-power.py
                        GPIO.add_event_detect(RESETPLUS, GPIO.BOTH, callback=button_pressed, bouncetime=2)
                        GPIO.add_event_detect(POWERPLUS, GPIO.BOTH, callback=button_pressed, bouncetime=2)
                        • megakoni
                          megakoni @unik314r last edited by megakoni
                          @unik314r but i have a power switch, not a button. My Reset trigger is a momentary button. for power i use a switch (i build my raspberry into a snes case)
                          and i use the system.power.switch=PIN356ONOFFRESET that was commented in the recalbox.conf.
                          And by the way, how and where can i find this script? And can i simply edit it?
                          • NeeeeB
                            NeeeeB last edited by
                            Have a look here :
                            /recalbox/scripts/
                            Vieux geek ^^
                            • unik314r
                              @megakoni To edit a file: have a look at https://github.com/recalbox/recalbox-os/wiki/Edit-the-config.txt-file-(EN)
                              The file you're looking for is /recalbox/scripts/rpi-pin356-power.py .
                              I Also use a modified SNES but don't like switch buttons (Recalbox python script looks for a status change --> going from on to off is the same as going from off to on and I find it not very convenient)
                              So I turned the original power switch button into a momentary one (inside the SNES, a simple spring makes the button go back) so that when I want to turn on (or off) the SNES, it pushes a momentary button (that I glued inside the snes) and automatically comes back: that way, even if there is a general power cut and then power restored (or something else that electrically unplugs/plugs the SNES), the system doesn't boot with a power button positionned to off.
                              But I suppose this is not what you're looking for^^
                              • megakoni
                                @unik314r thanks for the info. I also thought of glueing a button in the inside, so the "switch" then just bounces back.
                                But i think i stay with the switch. I just really enjoy that satisfying click sound and feel of using that original switch.
                                Then i'll just have to shut down switching 3 times or using the menu command. At least i get no shut downs anymore when i plug in something to usb etc.
                                • unik314r
                                  @megakoni I agree with you, the switch sound is oddly satisfying 😄 But I have it on my original non-modified SNES 😄 😄
                                  100.2k
