    PS4 Controllers configuration with retroarch custom config Problems
    GamePad/GPIO/USB encoder
    ps4 retroarch config
    7420
    • eightkiller
      eightkiller last edited by eightkiller
      Hy, i got a problem with my custom retroarch config with PS4 controllers. Only the joystick is working and I don't get why. Before I was using 8bitdo SFC30 pads and it was working flawlessly
      Here is my config:
      input_joypad_driver = sdl2
      #input_player1_analog_dpad_mode = 1
      #input_player4_analog_dpad_mode = "1"
      input_enable_hotkey = "escape"
      #input_exit_emulator = "escape"
      input_player1_joypad_index = 0
      input_player1_up_axis = "-1"
      input_player1_down_axis = "+1"
      input_player1_left_axis = "-0"
      input_player1_right_axis = "+0"
      input_player1_up_axis_label = "D-Pad Up"
      input_player1_down_axis_label = "D-Pad Down"
      input_player1_left_axis_label = "D-Pad Left"
      input_player1_right_axis_label = "D-Pad Right"
      #input_player1_up_axis = -1
      #input_player1_down_axis = +1
      #input_player1_left_axis = -0
      #input_player1_right_axis = +0
      input_player1_a_btn = 306
      input_player1_b_btn = 305
      input_player1_x_btn = 307
      input_player1_y_btn = 304
      input_player1_l_btn = 308
      input_player1_r_btn = 309
      input_player1_select_btn = 312
      input_player1_start_btn = 313
      input_enable_hotkey_btn = 316
      #Controls with Hotkey
      input_load_state_btn = 307
      input_save_state_btn = 304
      input_state_slot_decrease_axis = +1
      input_state_slot_increase_axis = -1
      input_menu_toggle_btn = 305
      input_exit_emulator_btn = 313
      input_screenshot_btn = 308
      input_hold_fast_forward_axis = +0
      input_rewind_axis = -0
      I checked the numbers with sdl2-jstest
      I was using the same syntax with just different numbers for my 8bitdo.
      What did I do wrong ?
      Thanks in advance.
      P.S.
      Before I was using this for example for my P2,P3,P4 with 8bitdo pads:
      #Player 2 Settings
      input_player2_joypad_index = 1
      input_player2_up_axis = "-1"
      input_player2_down_axis = "+1"
      input_player2_left_axis = "-0"
      input_player2_right_axis = "+0"
      input_player2_up_axis_label = "D-Pad Up"
      input_player2_down_axis_label = "D-Pad Down"
      input_player2_left_axis_label = "D-Pad Left"
      input_player2_right_axis_label = "D-Pad Right"
      #input_player2_up_axis = -1
      #input_player2_down_axis = +1
      #input_player2_left_axis = -0
      #input_player2_right_axis = +0
      input_player2_a_btn = 170
      input_player2_b_btn = 171
      input_player2_x_btn = 173
      input_player2_y_btn = 174
      input_player2_l_btn = 176
      input_player2_r_btn = 177
      input_player2_select_btn = 180
      input_player2_start_btn = 181
      #Player 3 Settings
      input_player3_joypad_index = 2
      input_player3_up_axis = "-1"
      input_player3_down_axis = "+1"
      input_player3_left_axis = "-0"
      input_player3_right_axis = "+0"
      input_player3_up_axis_label = "D-Pad Up"
      input_player3_down_axis_label = "D-Pad Down"
      input_player3_left_axis_label = "D-Pad Left"
      input_player3_right_axis_label = "D-Pad Right"
      #input_player3_up_axis = -1
      #input_player3_down_axis = +1
      #input_player3_left_axis = -0
      #input_player3_right_axis = +0
      input_player3_a_btn = 170
      input_player3_b_btn = 171
      input_player3_x_btn = 173
      input_player3_y_btn = 174
      input_player3_l_btn = 176
      input_player3_r_btn = 177
      input_player3_select_btn = 180
      input_player3_start_btn = 181
      • eightkiller
        Still nobody to help ? I can't manage to make my controller work in 4.1. No one is answering multiple posts 😞 A lot less help than before !
          Substring @eightkiller last edited by Substring
          @eightkiller a lot more people asking for support, but still the same 3 sheep to answer ...
          Why don't you let Retroarch set your configuration ? Just look for the "Bind player 1" option, remap, save and then edit files accordingly !
          Your DS4 is not using the SDL2 input driver but the udev one. So I'm not sure you get the right values from sdl2-jstest
          • eightkiller
            Yeah, U seem to have a lot of requests ! :s
            In fact I'm using a custom retroarchconfig for setting overlays for differents emulators (for example 😞
            # Settings made here will only override settings in the global retroarch.cfg if placed above the #include line
            input_remapping_directory = /opt/recalbox/configs/snes/
            input_libretro_device_p2 = "257"
            video_shader_enable = false
            # We dont need them
            video_fullscreen_x = 1920
            # Horizontal Monitor resolution
            video_fullscreen_y = 1080
            # Vertical Monitor resolution
            custom_viewport_width = 1194
            # Horizontal emulator resolution
            custom_viewport_height = 896
            # Vertical emulator resolution
            custom_viewport_x = 363
            # The first X pixel of the emulator image
            custom_viewport_y = 92
            # The first Y pixel of the emulator image
            aspect_ratio_index = 22
            # Aspect Ratio set to custom
            input_overlay = /opt/recalbox/emulators/retroarch/overlays/16-9/Scanlines_4x_1080p_Borderless.cfg
            # Overlayimage
            input_overlay_enable = true
            # Overlay Image enable
            input_overlay_opacity = 0.7
            # opacity of the overlayimage
            input_overlay_scale = "1.000000"
            # Scalesize of the overlay image
            video_smooth = true
            # Smoth the emulated image, not the overlay, If you set it to false, it will remain sharp but blocky.
            #include "/recalbox/configs/retroarch/retroarchcustom_PM.cfg"
            Could you just tell me where is the default retroarch.cfg that recalbox is using (just to be sure) ? I will #include it instead of my custom that I created with the input_player things that I showed on my previous post.
            I suppose the Bind player 1 option is located inside this file ?
            Thanks in advance.
              @eightkiller by bind player 1, I just mean to reconfigure your pad the standard way in RA, nothing more.
              If you need an overlay, you could simply edit ~/configs/retroarch/retroarchcustom.cfg.originand add your default options (but player inputs) there. I don't think i've managed a default overlay configuration file on each system, it's a per game basis i'm afraid (for now)
              eightkiller 1 Reply Last reply Reply Quote 0
              • eightkiller
                eightkiller @Substring last edited by eightkiller
                @substring You can, I created one retroarch.cfg associated with each console and referenced it in recalbox.conf like this:
                #recalbox.conf
                snes.configfile=/opt/recalbox/configs/snes/retroarch.cfg
                gb.configfile=snes.configfile=/opt/recalbox/configs/gb/retroarch.cfg
                and inside each of those .cfg files, I associated specific overlays and viewports for each console like this for example
                custom_viewport_width = 1379
                custom_viewport_height = 1035
                custom_viewport_x = 290
                custom_viewport_y = 22
                # Overlayimage
                #include "/recalbox/configs/retroarch/retroarchcustom_snes_PM.cfg"
                and at the bottom of each of thoses .cfg files I include
                another custom .cfg file corresponding and replacing the recalbox generated retroarchcustom.cfg
                For example:
                #retroarchcustom_snes.cfg
                #here I define everything related to my controllers and so on like that I can use specific controllers for each console
                #8bitdo SFC30 for super nes, PS4 controllers for PSX and arcade game, etc...
                #A part of the config for the example
                 input_joypad_driver = udev
                #8bitdo SFC30 Gamepad
                input_player2_analog_dpad_mode = 0
                input_player1_a_btn = 0
                input_player1_b_btn = 1
                input_player1_y_btn = 4
                input_player1_l_btn = 6
                input_player1_r_btn = 7
                input_player1_select_btn = 10
                input_player1_start_btn = 11
                And to find the proper configuration for my controllers, I first let recalbox set the defaults config, opened the retroarchcustom.cfg generated and checked the proper buttons number. Then I could create proper files for each controllers/consoles 🙂
                And it's working flawlessly, it's really close to real consoles like this 🙂
                  @eightkiller Stupid me : you can make things almost automatic with no editing. Just add a <system name>.cfginside ~/configs/retroarchand the file will be automatically loaded. For example : ~/configs/retroarch/snes.cfg
