    Detailed View disable on NeoGeo ?
    detailed view disable neogeo
    • odissine
      odissine last edited by
      Hello all,
      I've got an issue even after scrapping NeoGeo System ... After rebooting system, NeoGeo system appear with basic view instead detailed view.
      I've got download_images with all png inside with same name as roms ... but nothing happened...
      I tried to scapp only one game ... view is now detailed but only the roms I scrapped has got a picture ... others don't 😞
      Is there anyway to force detailed view ? Why even if all png files are in folder downloaded_images with same name I can't see anything ?
      Thanks for your help
      Recalbox 4.1
      Roms on USB Key 128Go Samsung
        Substring @odissine last edited by
        @odissine Hi,
        Saw your issue on github, i'd have closed it and asked you to post here. But you had the good reflex !
        So, I'd remove the gamelist.xml file, make a fast shutdown, and rescrape
        • odissine
          Thanks Substring that's works !
