    Get started to write my own game? (I am a programmer)
    Community projects
    started write own programmer
    3119
    • mfkenson
      mfkenson last edited by mfkenson
      Hello world!
      I am new to the recalbox world and I actually come from raspbian.
      I know what raspberry pi could do generally. And the recalbox project seems very powerful on playing existing roms. However I would like to write my own game. Probably a simple mario-like game or RPG.
      how to get started? any directions would be good. I still have no idea after looking the FAQ and google search.
      voljega paradadf 2 Replies Last reply Reply Quote 0
        voljega Banned @mfkenson last edited by
        @mfkenson Hello I would advise to try with pico-8 which is pretty straightforward, although the documentation is sometimes unclear.
        It is not free, it costs somewhere around 15€
        Even if you end working with another game motor, pico-8 is simple and very good to learn the base of 2D game programming
        @acris and I even worked on a unofficial integration into recalbox which you can find in my signature
        others candidates : game maker, unity, but you won't be able to use them on the pi
          paradadf Staff @mfkenson last edited by
          @mfkenson out of the box you could check the lua framework (lutro emulator) wich is already part of recalbox.
          EasyRPG has a libretro port as far as I know, so you could think of integrating it into recalbox if programming for it is an option.
            voljega Banned @paradadf last edited by
            yep @paradadf is right, lua is good too, and pico-8 uses a subset of lua
            • mfkenson
              thank you guys. @paradadf @voljega
              lua is good to me. Seems pico-8 is a good start!
              I found your code repo in github. will definitely try that!
              • mfkenson
                I am impressed the tiny pico-8 could do all tasks including game development.
                However it seems that it is not efficient to do the development in that window, is it?
                Meanwhile I am reading the https://github.com/felipebueno/awesome-PICO-8 .
                (https://github.com/movAX13h/P8Coder seems good.)
                What is your recommended way to program?
                  @mfkenson I didn't programm that much with it but the included editor inside pico8 is maybe simple but usefull too.
                  I see you found the awesome github, everything should be in it, I remember someone writing something allowing the editing of the cart's code through notepad++
