    Wii : How to access ingame Dolphin menu ?
    Emulator Arcade/PC/Console
    wii ingame dolphin
    • Maldorhan
      Maldorhan last edited by
      Hi,
      I made a separate topic since it's not related at all : how can I prompt the ingame Dolphin configuration menu (if any) to tweak settings (needed according to their wiki for a few games) ? I can't find the shortcut if any.
      If it's not possible, where could I specify those settings for each game within Dolphin or ES through SSH ? Maybe a config file somewhere ?
      Thanks guys !
      RPi0W / Retroflag GPi CASE
      RPi3B+ / Retroflag SUPERPi CASE-J
      Retroflag NESPi CASE v1
        Hello, you can't
        • Maldorhan
          @rockaddicted Alrighty thanks !
          • Ron Carter
            Ron Carter last edited by
            I'm able to pull up the dolphin main program by Hot button plus my R2. I cant recall what the R2 is mapped to. This lets me get in and tweak the emulator settings.
              paradadf Staff @Ron Carter last edited by
              @ron-carter I believe ALT+F1 should work.
