    Libretro_fba Bug?
    ntp static ip i
    2134
    • tlanks
      tlanks last edited by
      I used usb SNES joypad  in Libretro_fba In all capcom games, coin key do not work !But hotkey goes well others are good After that ,I found out all the joypad which has only "up down left right A B X Y   select start L R "but"L2 R2 " show this bug! why? how to fix it ?
      • tlanks
        in other EMU is good
          Hello does the same problem in this : https://github.com/digitalLumberjack/recalbox-os/issues/251
          • tlanks
            his bug is GPIO joypad   my is SNES joypad But these two are all  no L2 R2 pad make any button  HOTKEY  ,the HOTKEY works make select  buttion  select (coin in) key , the key do not works make L  buttion  select (coin in) key , the key  works     why ? maybe i need more try ?
              May be gpio joypad but it's the same bug, you must change select hotkey by L hotkey I dont' know why but i open issue.
              • digitaLumberjack
                Hi @lyn 🙂 It's interesting what your are saying :
                After that ,I found out all the joypad which has only « up down left right A B X Y select start L R « but »L2 R2 » show this bug!
                Are you sure that a fully configurated joystick (with L2 and R2) but with Hotkey on select (what you must have on the snes controller) works. Until now, i though the bug was only due to the hotkey on select button.
                • tlanks
                  yes U are right <span style="color: #737c85; font-family: 'Open Sans', sans-serif; font-size: 12px; line-height: 26px;">the bug was only due to the hotkey on select button.</span> can you fix it ?
                  • digitaLumberjack
                    Nope i can't it due to the libretro implementation. I have no skills on that part of the emulation. Maybe someone will fix it one day.
