    4.1 stable: Bluetooth Lag
    4.1 stable bluetooth lag
    • ejr
      ejr last edited by
      Hi, I have third party ps3 controller that is only seen by recalbox when I change config to controllers.ps3.driver=official (gasia sixaxis). So I've done that, the controller is paired, everything works in menu. In emulators I have HUGE input lag. And I mean really huge, like 2-3 seconds and its getting even worse when I do reconnect mid-game. Is there something I can do to fix that?
        Substring @ejr last edited by
        @ejr play next to your pi, like "not 2m far from it" ?
        Are you using the internal BT or a dongle ?
        • ejr
          ejr last edited by
          Yep, I was testing it when I was staying like 1,5m from the pi and I'm using internal BT.
