    N64 c button mapping.
    button mapping
    • rMac
      rMac last edited by
      Hello all. I have been working on a DIY arcade using a raspberry pi and recal box. One thing I was really looking forward to was playing some of the n64 games I lost over the years. Specifically Starfox64 and DonkeyKong64. Both of these games require c buttons, which I cannot figure out how to map on my arcade set up. Looking for options (either mapping on buttons/joysitick, or buying an n64 controller with usb connection). Any and all advice is appreciated. Thank you.
        Hello
        you need PSX ou xbox360 gamepad to play N64 games.
        rMac 1 Reply Last reply Reply Quote 0
          voljega Banned @rMac last edited by
          @rmac n64 uses analogic stick wether arcade just uses digital joystick, so anyway n64 on a bartop doesn't have too much sense
          • rMac
            rMac @acris last edited by
            @acris thank you for the reply. I will make sure to include external usb ports for xbox controllers so I can play the 64 games.
