    GPARTED - moving from 32GB to 64GB
    gparted moving 32gb 64gb
    • kryptto
      kryptto last edited by
      I have seen on posts before that you can re-partition the "Share" partition to the new open space.  I have the GPARTED on a LiveCD and it see the SD card slot of my laptop.  How does or what is the correct way, any instructions?  i am lost, I keep destroying the partitions.
      PI 3B+ Recalbox 4.1
      • digitaLumberjack
        You must resize the fat32 partition (share), which is a logical partition located in the extended partition.
        • kryptto
          Thanks Retro (tips hat)
          PI 3B+ Recalbox 4.1
          100.8k
